Question about Mitsubishi WD-52525 52" Rear Projection HDTV
No picture and no sound after replace lamp for Mitsubishi WD-51525
Had Mitsubishi WD52525 for about 2 years. the screen indicated replacing lamp was needed. After replaced the lamp, powered on the TV, green light was on, but no picture and no sound, then red light on. the TV no longer works.
Any available solution? Thanks.
  • 5 more comments
  • Anonymous Nov 26, 2008
    wd-52627, wd-62627
  • kbriner Dec 19, 2008
    same issue, tv will not come on, power light comes on and after about a minute it switches over to solid red lamp light. replaced lamp and still has the same issue. after lamp light comes on the fan shuts off but the lamp light will stay illuminated until I either reset tv or unplug it. any suggestions? Thanks.
  • brazilef Dec 31, 2008
    I have a HD tv and the green light comes on when I turn it on but the screen has no picture. The screen is pitch black and there's no sound. Do you have any idea as to what the problem may be?
  • brendarh Dec 31, 2008
    I have the same problem. No picture, no sound, no response to remote. Red lamp light on. Replaced lamp & green power light comes on for a minute, lamp lights up, then goes out & red lamp light comes back on. Spoke to the store & they said it may be the chassis which went bad on a lot of those tvs. Was that part recalled? Is it something I can replace myself?
  • Anonymous Jan 01, 2009
    yes, i have had this same problem and mitsubishi is right now working on letting me know how they will compensate for $750 worth of lamps I have had to replace and television now needs a fifth lamp.
    TV has not worked properly since it was new. Previously could always "fix" it by unplugging it. (Service calls when under warranty were useless/pointless). TV failed completely - black screen, no audio - last week. Changed lamp, same problem; green light comes on, fans make noise, then in shuts off and steady red light illuminates until set is unplugged.
  • Any Guy
    Any Guy May 11, 2010
    Do you feel comfortable taking the set apart and replacing components?
I was having the same issue after a lamp replacement and the warranty tech said that it was the lamp power supply that went out. The part was on back order and look at the board neaqr the lamp and it had a blown capacitor. This would make since why the lamp would come on then shut off right away. She replaced the capacitor and works fine.
Posted on Jan 02, 2009
  • 179 Answers
Did you use an original mitsbishi lamp. did it slide in easily? one of the most common problems with a lamp replaement is pushing the connector away from the lamp if it doesn't slide in easily. unplug the set, take out the lamp and look with a flashlight to see if the connector is in place. if so put the old lamp in and see if it works. if it does then your new one is bad. if it doesn't then email me with your number and we can talk more.
Posted on Nov 11, 2008
Sound but no picture; little red light showing instead of green led power indicator. less than two years old. original owner
Tv LED light indication"LAMP" is flashing or staying on?Yes 2 years old projection lamp and watches tv daily 4 or 5 hours a day?Yes,it is time to replaced the tv projection lamp.
Feb 18, 2011 | Mitsubishi WD 65837 65 in. HDTV
I have a 65" Mistubishi WD - 65734 and have no
Yes,"LAMP" LED light indication front of tv bazel frame is on or blinking,yes mean tv projection lamp life are over.The whole tv warrenty only for a year,tv projection lamp should last at leat 1 1/2 or 2 years,by tv been on and watches used it like 4 or 5 hours daily?U never done tv replacement parts,any kinds before?Yes,hire a tv Tech. to do it.Shop around for a Tv tech.should replaced the projection lamp for u shoud be around $250 to $300 that including part the projection lamp.
Jan 03, 2011 | Mitsubishi WD-65734 65" HDTV
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
No Picture but still has sound
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it : It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is 915P049010. you can find it here: a blessed one!
May 03, 2010 | Mitsubishi WD-57731 57" Projection HDTV
We have sound and a blue screen with no picture
Your ballast might not be able to light up your lamp. Do you hear a clicking, buzzing? this can be an indicator that your ballast is too weak to light up the lamp. this board will need to be replaced at some point of your tv's life.
Apr 13, 2010 | Mitsubishi WD-65833 65" HDTV
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-65733 no picture, electrical buzzes in series
What it sound's like is that the lamp ballast is the problem. Buzzing sounds like when the power is first brought to the ballast it has to ramp up the voltage to get the lamp to light, then the voltage drops back down when the lamp is lit. Sounds like the lamp ballast isn't ramping up the voltage the way it should. May have to replace it. A good service shop would be able to do this for you.
A/V Media Guy
Nov 20, 2009 | Mitsubishi WD-65733 65" HDTV
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
I have Mitsubishi WD-62525. Last week I turned TV on and there was no picture, on green horizontal lines across the screen. The picture then went black and I only have sound. The lamp indicator lite turned...
that is a common problem with that model you will need the v26 power pwb repair kit and the V26 FMT pwb repair kit. You can get both kits at the following link which includes the replacement capacitors and instructions on where the capacitors are located. Heres the link.
Sep 26, 2008 | Mitsubishi Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
217 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
