Question about Emerson EWF2703 27" TV
Emerson EWF2702 27" TV
Picture looks like it has white smears mostly on the right side of the screen especially when there is bright pictures, what can I do?
  • losjlozanos Feb 23, 2009
    It looks like my flat screen tv had a fog patch, but only on the left upper corner and only during bright pictures. Obiously since its a flat screen I do not have any thing sitting on it. I do have a atomic clock sitting in front by that side. So I did move it, hoping that might help. I will sign in and rewright weather it helps or not.
    Problem Solver:
  • 15 Answers
I had the same problem it ended up being the speakers I had on top of my tv, so I had to move them. If you have anything on top of your tv with a signal move it. :)
Posted on Nov 23, 2008
White lines on image however when capturing on dark areas and on video mode, it produce a perfect image
Not clear when you have white lines. While looking on the screen or really on a image.
Lots of camera's produce lines on the LCD, when using the LCD to frame the picture. Special when there are small and sharp lights in the image. But the sensor is not capturing that while making the picture. It is a sort of smear on the screen.
Also, when you try to make a picture in bright lights, you can get flares, but those you can see on the screen and in the picture. To fight flares, most camera's and lenses come with sun hoods. Your camera does not have a hood, so try to avoid shining bright lights on the front of the lens.
Nov 05, 2013 | GE 14MP Digital Camera with 5X Optical...
I have power to my Sony Bravia KDL TV but no picture MOST of the time, especially when the TV is cold. Does a bulb go out gradually or does it go out all at once?
is there still a back light just no picture. shine a light on screen and look at the picture from the side if you can just see the picture then the inverter is on its way out. if you get a white or gary coulor screen then the screen driver is on its way out.
Sep 21, 2013 | Sony BRAVIA Televison & Video
Some channels on my tv are dark and tinted orange, I used the menu button to display the menue and scrolled down to picture but I did not know how to select picture.
Hello
Adjust colour control to zero, and check for a pure black/white picture. Adjust contrast and brightness control to minimum and check whether the picture goes completly off or a slight picture prevails. If the picture goes out when you turn down brightness control to 1/3 position, that is about 20 points, your TVs screen voltage is very low, and it can be adjustable. If the picture does not go out and more brightness prevails, screen voltage is high. If the screen voltage is high, there will be some fine lines across the screen at about an inch apart; on the whole screen from top to bottom.
Screen voltage adjustment is critical for the clarity of the picture. If it is low, no proper colour will be dispayed. If it is high, it is harmful to both picture tube and your eyes.
Never try to adjust it without proper knowledge about it. The screen control can be located alongwith the LOT [Line Output Transformer], of your tv. There will have two adjustable controls there, one is for Focus, and the other is for Screen. Both are interactive, that is adjusting one will effect an other.
Oct 18, 2010 | Emerson TS2587D 25" TV
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
LCD TV has dark smears on picture
This not repairable,it a LCD screen have minor pixels cracks in the LCD screen itself,some body hit the LCD Screen with somethings.
Jan 12, 2010 | Panasonic VIERA TX-26LXD80 26 in. HD-Ready...
Sound but no picture
GE TV CTC 203 the oicture is very cloudy
Dec 14, 2008 | Televison & Video
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Emerson EWF2704 problem
Look for vertical output LA7804 7-PIN IC near right rear of set on heatsink. Look for bad solder joints in that area also.
May 25, 2007 | Emerson EWF2704 TV
Picture smear and screen brighter on the right hand side
If you know how to read a service manus then what you are looking for is a possible bad cap on the 200v source feeding the video output collectors or video output IC. That is the first suspect.
Apr 05, 2007 | Sylvania SST4322 32" TV
Mitsu HD1080
There is a possibility that the problem lies on the "Doubler" circuit board with this set, especially if the darkness looks like a smear in the picture during bright scenes like a hockey game.
Mar 13, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Emerson EWF2703 27" TV Logo
282 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
