Question about Black & Decker MX50 PowerPro® Mixer
How to disassemble Black & Decker MX50 PowerPro Mixer
Have subject mixer and the beaters "suddenly" jammed. Wondering if a gear slipped a tooth?
I can't figure out how to separate the bottom from the top. I can't drop the speed control switch assembly down through the handle so as to remove the bottom/motor. The power-boost button hangs up on the handle where your index finger would go.
Wondering if there is a screw or clip holding the power-boost button to the speed switch. Once disconnected, then the speed switch would drop down and out of the handle. If there is a connector, appears the back of the handle comes off to get at it. There are clips at the bottom of the handle's back, but afraid of breaking the clips.
  • 273 Answers
Regarding worn gears in cheapo Made in China mixers: The left gear wears symetrically different from the right due to torque and rideout. A temporary fix involves switching (juxtaposing) them left into right, vice-versa. Be sure to observe the position of the beater key slots beforehand to ensure that the beaters won't interfere with each other after reassembly. One is usually 45 degrees advanced from the other I / . You might have to remember that the beaters go in opposite of the way they used to.
Posted on Jul 11, 2010
To remove the upper part from lower part, the trick is to remove the " eject" button. Once all the handle is free, try to back off the eject button, then you'll see it will get loose from it's shoulders, now you can pull it up.
Posted on Dec 19, 2009
I have the same "jamming beater" problem. I was able to get the mixer apart following the advice in Solution #1 (thanks). There is no need to separate the handle, unless it lets the "power boost" button move to the back of the mixer (thus sliding it off the referrenced micro switch). I was able to pry it until it came off the switch, at which point the mixer fell apart in my hands.
I believe the "jamming beater" problem is caused by one or both of the large white gears being worn down so that it or they no longer engage the gray worm gear. If one white gear fails, the other beater turns until the beaters jam. I'm now looking for replacement gears, but I imagine it's cheaper to just replace the mixer.
Posted on Dec 04, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
You can remove the handle-back by gently prying the rear clips down and away. But the problem is the power boost button; it has a fork that goes down the left side and snaps over a micro-switch. You need to get that off since there is not room for all 3 buttons (eject, variable speed, and boost) to slide through the handle. A small probe inserted from the top and pushing on the left side to the rear might do it. Or just pry the boost switch upwards; that's how I got mine apart. My problem was the boost microswitch was bad and provided a poor connection. As a result, the beater only ran intermittently on regular switch positions. I solved it by bypassing the boost micro switch. The beater now only runs on the regular speeds but that's fine by me.
Posted on Jan 06, 2009
I need a charger for powerpro hp6model
I would try to purchase one by searching eBay.com, and if necessary, if the price is right for you, purchase a replacement model of the same kind if necessary. I have to assume it is a Black and Decker model, but let us know if you can enter the model number and make information in the comments block, please.
Examples using http://www.google.com and the word Power Pro HP6
https://www.ebay.com/p/Black-Decker-MX50-PowerPro-Mixer/69803368
Black Decker MX50 PowerPro Mixer
Apr 08, 2018 | Food Mixers
Nylon gears stripped on hand mixer beater gears
Unfortunately, modern small appliances are considered "disposable" by the industry. So there are no "better made" parts. The best you can hope for are the same as what was originally installed. Try https://www.ereplacementparts.com
Dec 29, 2013 | Black & Decker MX50 PowerPro® Mixer
Need to replace the whipping mixers for my Black and Decker MX350
First I would check the yellow pages or my chamber of commerce
for a reputable dealer or repair station. If that doesn't work, try
Dec 28, 2009 | Black & Decker MX50 PowerPro® Mixer
Need replacement beaters
Black & Decker MX77 PowerPro® 220 Watts Hand Mixer Black & Decker MX77 PowerPro® 220 Watts Hand Mixer - User Rating: 4 stars. ... There are no signs of rusting around the metal parts. Overall ...epinions.com/review/pr-Black_Decker_MX77_Mixer/...
Nov 02, 2009 | Black & Decker 220 Watts MX77...
The beaters were clanging together. Now the
the gears were out of sync, by this time their probly stripped. IF you can get the gears, one must resemble a X and the other must resemble a + when installed, so they look like this X+ that way they wont hit.
Oct 17, 2009 | Black & Decker 220 Watts MX77...
Replacement beaters
I had an SM100 which did not work when I got it out to make cookies recently. So, I have both bowls available (large and small), beaters, dough hooks, whisks and the use and care book too! I sure will miss that mixer. Contact me at lindareagan@comcast.net
May 29, 2008 | Black & Decker MX55 PowerPro Hand Mixer
Replacement beaters for hand mixer
Hi, replacement beaters can be found easily on amazon, click here and take a look: Amazon com hand mixer beaters. Wish you best of luck.
Jerry
Jul 14, 2007 | Black & Decker MX55 PowerPro Hand Mixer
Black & Decker MX50 PowerPro® Mixer Logo
862 people viewed this question
Top Black & Decker Food Mixers Experts
Jerry Greenberg
Jerry Greenberg
Karl Kittsteiner
Are you a Black & Decker Food Mixer Expert? Answer questions, earn points and help others
