Question about Toshiba 27A51 27" TV
Toshiba 27A51 problems
Can anyone help me with the part number for a Toshiba TV model # 27A51 IC location 501 this is a 5 pin regulator Thanks all for ur help.
  • mitchel taylor Oct 27, 2006
    IC, STR-G6624
    Toshiba Part Number: 23135012
    Toshiba Model: 27A51
    IC, STR-G6624
    i found it @http://www.circuitcitypartsearch.com/Pro...
Reduce raster no picture no sound and the power stays on.
Posted on Aug 29, 2007
Could i fix my tv screen
Replace the CRT base connecting socket. It is bad.[Corroded Focus pin connection]. Can be located at the CRT base card.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 12, 2014 | Toshiba 27A51 27" TV
46RV535U 46 in. HDTV LCD TV where is the fuse
There are several fuses on the power supply board.
Usually the one that fails is not the main AC line fuse (which is close to the AC line input), but the PFC fuse located, you guessed it, next to the PFC regulator IC on the board.
When the PFC fuse is blown (measuring open) you also need to replace the PFC IC and possibly other components on the board. Most of the time the PFC is sufficient though.
Here's a link for repair service for the board:
http://www.coppelltvrepair.com/p/751/toshiba-46rv535u-power-supply-board-repair-service-for-dead-refusing-to-power-tv-or-faint-display-problem
Also search there for the TV model, we may have repair kits or exchange services available!
Hope this helps!
Jul 30, 2012 | Toshiba Regza 46RV535U 46 in. LCD HDTV
Where can I buy an STR-4525 transistor for my Toshiba Rear Projection tv?
That is a drawing number for the IC itself. I will need the model of the TV and the location number for that IC to be able to look up the Toshiba part number. The location number will be silk screened onto the pc board where it came from.
Dec 02, 2009 | Toshiba TP55G60 55" Rear Projection...
D52W19 Regulator IC part number.
There are many regulator IC in TV you can find it easy the commonly used are 3 pin part number is 4 digit example LM7809/AN7809 this means possitive ic regulator 9v output. LM7909/AN7809 means neg. output 9V. so you can search it on your board. Good Luck
Jun 01, 2009 | RCA D52W19 52" Rear Projection Television
Toshiba no video sound is fine
If you can see the menus this means the CRT, high voltage, scan amplifiiers, the output video processor, and CRT drive circuits are working. The fault is most likely in the video section of the input select circuits.
Maybe the Toshiba parts department can supply a service manual for your set. With a signal source, a scope, and a DVM, an experienced technician can troubleshoot your set to locate where the failure is occuring.
I have not serviced this model, but in other models I have found the main input select IC to be defective. In some cases I also found a bad voltage regulator IC that supplies the input section has failed.
Jerry G.
Dec 16, 2008 | Toshiba 36A42 36" TV
Television power led blinking
are you sure that you are checking this correctly?
What is the location number for this regulator?
If its the main regulator, what are you using for ground on your meter? Also, isn't the part number marked on the regulator?
Apr 12, 2008 | Toshiba 27DF46 27" TV
Toshiba 32" HDTV 2002
The power regulators are famous for going bad. The big problem with this TV set is that unless you use the exact regulator from Toshiba, this set will fail time and time again. Even if the regulator IC has the exact same number, it will not hold up. We used to have a shop that was authorized by Toshiba, and we seen this problem many times when customers would say that they had their TV fixed by some local shop and the same problem occured several times. Good Luck
Mar 28, 2007 | Toshiba 32AF41 32" TV
Toshiba 27A51
check brightness and contrast setting haven't been reduced to zero.
Aug 28, 2006 | Toshiba 27A51 27" TV
Toshiba 27A51 27" TV Logo
66 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
