Question about Nakamichi CD-40z CD Changer
Volume my nakamichi cd -40 does not get loud, it stays at a low volume, if it can not be fixed can I my just buy the detachable face and fix the problem? rich111putt@sbc global.net
  • rich111putt Nov 10, 2008
    I checked the switch, unscrewed the face plate, but I do not see how the switch can be
    replaced. are there people that fix these or do I ned to replace the detachable face plate? If I have to replace, who does this in 91801?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Ur volume control fadder has failed in the lower control side of the volume. (its just a variable resistor) refer service to qualify service personel around u
Posted on Nov 10, 2008
  • 6,487 Answers
    Sergeant:
    Novelist:
  • 196 Answers
First check out if the swich from which the sound is increased is broken or worn out in the system front pannel. thanks.
  • mmechanics Nov 10, 2008
    Main support number310-392-1155
    Support FAX310-392-1030
    Email supporttechnicalsupport@nakusa.com
    check out this
    u can try any professional technician for chiplevel reparing in you area near by,that person can do it for u.
    thanks.
The volume wont go higher than 12 on my Jensen Mcd5110 Marine Radio/am/fm/Cd receiver W/Detachable face, how can I fix it to go all the way up to 26 plus?
take off the bottom cover ,find the volume switch on the outside then find it on the inside.Now get some WD-40 and spray the control on the inside with a very,very light squirt of WD - 40. Let it set for a while then try it.It should work.
Jul 09, 2012 | Jensen Mcd5110 Marine Radio /am/ Fm/ Cd...
Display not working
I have the same problem. There's a little ribbon cable behind the contacts for the faceplate. It gets folded as the face plate motors in and out and eventually breaks like mine did. I'm fixing it tonight and then I will disable the motorization. Followed by NEVER BUYING A PIONEER AGAIN. I reccomend you do the same.
Aug 05, 2009 | Pioneer DEH-P780MP CD Player
The volume on my LG VU phone is so low and I have the volume turned up as loud as it shows? I have to put people on the speaker to be able to hear them when a call comes in. This has just started and it is...
quit dropping your phone
just kidding
usualy mi phone does that after a few falls the speaker has most likely come detached from the case or there is **** in the speaker canal
take the phone to local shop spend 20 bucks and have them fix it
or option 2 take phone apart and investigate witch means go buy a new phone the next day as you will likely do more damage than repair to the case .
or option 3 buy a blue tooth for your phone they work great even a cheep one from tger direct or factorydirect.ca they sell for 20-100 so it's money well spent.
but it's your money
Jul 23, 2009 | LG Vu CU920 Cellular Phone
Set time on jvc car audio
I fixed this problem with info. from another posting. You push and hold the select button until demo comes on the screen, then release it and push the button that advances the cd. This will take you to the hour and minute screen. Turn the volume dial to set the time.
Mar 26, 2009 | JVC AM FM CD DET FACE CAR STEREO
Volume is low on my turntable
You have to amplify the output from your turntable output to the input of your amplifier. To do this you can buy what is known as a pre-amp. Radio shack probably still sells them.
Be sure to ground your turntable to your amplifier and not the pre-amp. This should stop any hum or at least diminish it. Bear in mind that your records will not sound as loud as your CD's. Hope this helps.
Feb 10, 2009 | Numark TT1520 Turntable
Need to fix the time
I have the the sony cdx gt 400 and the manual is of no help but I figured it out. You have two options...option 1 is wait until 1 o'clock and hit the small reset button on the radio behind your detachable face, or option 2 is a even better option. Press and hold the volume button in and options will appear...then by tapping the volume button you will cycle through the various options until you find "clock adjust" then press the small "display" button below the volume knob and also right next to the "source" button...the hour will flash turn the volume knob to desired hour then tap the volume knob or display button and the minutes will flash then turn the volume knob to the desired minutes, and you are done...hopefully this helps
Nov 14, 2008 | Sony CDX-GT400 CD Player
Sony cdx r3300 Won't play...simply scrolls a message
_half fixed, use the remote -@least can get more life outa the unit!
Nov 11, 2008 | Sony CDX-R3300 CD Player
PCD120U volume issue
i think I know what your problem is ... if you hold down the menu/select button ( the button between the volume buttons) there will be a volume option it'll say P --- volume. I think that sets a default volume that the cd player will always reset to once the cd player is turned off then on again.
Jun 02, 2007 | Phase Linear PCD120UCS CD Player/Receiver...
Nakamichi cd-35z
There is adjustment for bass, mid and treble. Access this by pressing the button to the right of the volume knob. I leave mine set at +1/2, -3, +2 . I also set LOUD on which is done by holding the same button down. With these settings everything sounds pretty spot on, occasionally need to adjust the bass up/down and treble dependant upon the CD.
Mar 09, 2007 | Nakamichi CD-35z CD Changer
Nakamichi CD-40z CD Changer Logo
Top Nakamichi Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Jaime Hernandez
Michael Galve
Michael Galve
Are you a Nakamichi Car Audio and Video Expert? Answer questions, earn points and help others
