Pioneer receiver model VSX-917V shuts suddendly down with OVERLOAD message
Hello, my pioneer receiver model VSX-917V started acting funny by suddendly shutting itself down when the volume gets a little higher. Before it shuts down I get a message OVERLOAD. I've had it for over a year and no problems until now. Please help. I checked all connections and everything looks fine.
  • Anonymous Nov 18, 2008
    we have the exact same problem. The tuner isn't even a year old and its suddenly started shutting down. Except for ours it happens at several different volumes. The connections all seem fine....any ideas?
  • 8546 Answers
SOURCE: my pioneer vsx-816 sshows overload then shuts
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 25, 2011
  • 3130 Answers
SOURCE: Pioneer VSX 915
Disconnect the speaker leads and see if this stops happening. If it does, connect up the speakers till the problem pops up, and that speaker that makes the problem happen is most likely bad. If the problems still happens with no speakers attached, then there is a problem in the audio output amp, and is going to need service , Good Luck
Posted on Jun 15, 2007
  • 979 Answers
SOURCE: overload
Ok, how much is "a bit"? If you are operating your unit at the 50% or more level, your unit is working as it should, as DVD and CD players output more signal than other sources...accordianman
Posted on Nov 26, 2007
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
  • 8546 Answers
SOURCE: pioneer vsxd412 overload
OVERLOAD indicator
This lights when an analog signal is too strong (the
SIGNAL SELECT needs to be on ANALOG). It
indicates the sound is distorting and the signal
should be reduced.
Posted on Dec 28, 2009
Pioneer vsx-d510
Disconnect all the speakers, and then check. Connect the speakers, one by one, and find which one makes it overload. That speaker is faulty. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Pioneer Audio/Video Home Theater Remote...
Overload pioneer vsx 808 rds
if it's shutting down when you increase the volume, this usually indicates a bad speaker.
Jul 03, 2013 | Audio Players & Recorders
Pioneer amplifier vsx-d512 overload message
This indicates the audio output stage in the receiver is loading down and triggering the overload protection circuit to kick in. Check the speaker wires for shorts, if okay! you will need a professional to assess the cost for repair.
Mar 31, 2012 | Pioneer Audio Players & Recorders
Display shows overload and receiver shuts down
This means that one (or maybe more) of the amplifiers is shorted. Remove all speakers cables and try again. If you get the same message that means that one (or more) amplifiers is fried. To find which and why you will have to open the unit and test the amplifiers.
Jul 31, 2010 | Pioneer VSX-D412 Receiver
Sir, i have an pioneervsx 917V-s , for
The user manual is available from here
Not sure which settings you want to change
Mar 31, 2010 | Pioneer VSX-917V-K Receiver
Power overload
That is a good thing, your receiver is going into "protect mode" that means the receiver is shutting down to keep from damaging delicate internal circuitry, it is sensing a speaker bottoming out or some other electrical "short" that could be damaging!
Also could be from over driveing the amp and then it starts to overheat thus going into "protect mode".
If your speakers are "clipping or distorting" turn it down, you are going to ruin your amp. Good luck !
Jan 06, 2010 | Pioneer VSX-516-K
OVERLOAD Message followed by receiver shutting down.
The First step in this would be to Check the Ohms Limit in the Manual and Compair to the Ohms on the Speakers that you are running and the Ones that came with it. Usually when you By the "Kit" the Speakers are Factory Matched with the Reciever. Let me Know!
Jan 02, 2009 | Pioneer Audio Players & Recorders
Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
Dec 28, 2007 | Bose 901 VI Main / Stereo Speaker
305 people viewed this question
