Question about Samsung DVD-R4000 DVD Recorder
DVD recorder -- displays blue horizontal lines only
I have a Samsung DVD-R4000 DVD recorder/player which was trouble-free until it suddenly failed -- the only image seen on the TV is blue horizontal lines, with a small horizontal band in the center which contains a distorted image of the DVD (or the TV channel to which the unit is tuned). It is unresponsive to commands from the unit, or the remote, except for Power (on and off). Have tried using it with another TV, using commercial DVDs instead, used unit as a tuner -- just blue lines. Nothing found on Samsung site, or in the manual. Ideas?
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 17 Answers
Most DVD players today are very inexpensive.
If your system is working well otherwise, I suggest purchasing a new DVD player. Try that solution. If for any reason it does not work then another problem may exist which may include an issue with your TV!
Posted on May 02, 2017
5 Suggested Answers
SOURCE:
SOURCE: samsung dvd-vr325 recorder player and samsung ln-t3253 H television
sell me your vr325 woolletj at gvsu dot edu
Posted on Jan 28, 2008
Drummernick
  • 440 Answers
SOURCE: New DVDs will not complete the format process.
try difert dvds one take +r only ok work better
Posted on Feb 09, 2008
axoplasm
  • 6 Answers
SOURCE: I have purchased a Samsung
Forget the mHz channels for now.
On the TV, or TV remote, look for a button that is labeled "Input" or "Video" or something like that. Depending on your TV, there might be a few choices that present themselves once you do this, such as "Video 1", "Video 2", etc. Keep going until you find what looks like the DVD player signal.
If there is no button as described, then look for another button on the TV remote or on the TV labeled "Menu". Then scroll thru the menu until you find "Input". Choices here might be "Cable", "Antenna", "Video". You'll want to choose "Video", or "A/V", or "Line".
Let me know...
---axoplasm
Posted on Nov 02, 2008
Geekman
  • 32281 Answers
SOURCE: dvd samsung D7500 region free code
You may be able to get it from one of these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/
www.download-info.com/dvd/index_new.htm
DVD and Blu-ray
www.videohelp.com/dvdhacks
Posted on Nov 19, 2011
Samsung DVD-R4000 not recognizing DVD-R discs
As a last resort you can try a firmware update if there is one but don't hold your breath. Unit may simply have lost ability to record and not be able to playback. Not uncommon - happens.
Sep 14, 2017 | Samsung DVD-R4000 DVD Recorder
Tip
No recording, open close error.
Details:
  1. Open - close error, can not load dvd and the led is blinking.
  2. After replace Main PCB, Loader and HD, conditions still same as before.
Follow this method:
Format the Hard drive, with steps as below :
a. DVD condition on --> Loading.
b. Press cancel button on remote until ST-BY appear on display set.
c. Press cursor up or down on remote until CD-UP appear on display Set.
d. Wait until formatting is complete.
Test open - close DVD.
a. If process open - close is normal, change the Assy Loader.
b. If Process open - close is fail , change the HD.
Damage loader can cause open-close error and error on HD.
on Mar 29, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
Record dvd player to dvd recorder to tv
take the dvd player plug white,yellow & red (line out) & plug these 3 wires into L1 or L2 in on dvd recorder (note on the recorder you must switch the channel from ch3 to either L1 or L2 to record from the player)....... now place the dvd you want to record in player & a blank dvd in the recorder.......press record (recorder)/ press play on (player)
feel free to rate the help
May 24, 2010 | Samsung DVDR120 DVD Recorder
Unit failed to read any discs
My unit all of a sudden fails to read any discs. It just makes noises that sounds like something is stuck. Then gives the message that its a proper disc. Its says no read.
Jun 20, 2008 | Panasonic DMR-ES25 DVD Recorder
Stops recording discs
certain discs will be ok then when u record something then try an play it it says th words no read then takes ages to get it out of th machine
Feb 25, 2008 | Samsung DVD-R4000 DVD Recorder
Display problems
Macrovision
An analog video copy protection scheme that alters the unseen part of a video signal such that a VCR or other macrovision enabled device may not record the video signal properly. There are several types:
- Automatic Gain Control
- 2-line color stripe
- 4-line color stripe
Symptoms of this include picture fading in and out or color banding of the signal.
Feb 06, 2008 | Zenith DVC2200 DVD Player
Ellion DVR-950S
Ellion DVR 950S Festplattenrecorder.
Please help me.
I have a problem, that the Power on/off Display get never out - it is a loop - power on an than power off power on .....
I diconnect the line (power cable), but it is the sam again. There is no more - other funktion by the recorder.
Thank you for help
walter-august
Jan 02, 2008 | Ellion DVR-530S DVD Recorder
Samsung DVD-R4000 DVD Recorder Logo
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
