Question about Durabrand 5.1 Surround Sound Computer Speakers
Back speaker static
The back speakers crackle whenever i try to watch most concert dvds or blu-rays, especially AC/DC ones for some reason. Even if I turn the volume to the back speakers down all the way. I never have this problem with any movie dvds or blu-rays or tv audio, only concert dvds and blu-rays. Is there anything I can do or do i need to replace my speakers?
  • 3 Answers
The system needs to be grounded
Posted on Sep 14, 2009
Static on HK395 satalite speakers
It might be beacuse of some sort of wireless interference like a cell phone.
Mar 10, 2014 | Dell HK395 Computer Speakers
Crackling static noice
Hi Roovejet.
The capacitor 104 is 0.1uf ceramic has no reading with analogue multimeter in any range of ohms scale.
if it read any of ohms value ,it is bad.
please check the large electrolytic capacitors too and loose connection for the board and.if you have volume controllers clean it with alcohol or contact cleaners.
if your device is older than 5 years it is time to change all the electrolytic capacitors.its sound like foolish but it brings new life and same quality when your buying time to the sound system.
regards.
nuwan
Jan 20, 2014 | Dell HK395 Computer Speakers
Amp crackling noise
Sounds like you could have a blown amp/speaker or you've got a short in your speaker lead. Typically, when there's not enough resistance on a wire is when you start getting the crackling noises.
Aug 06, 2012 | Televison & Video
I tried to install an aftermarket 6 1/2" speaker
possible reasons:
Impedance mismatch
wiring is grounding out on frame/metal
speaker isn't OEM and is slightly "pinched" thus causing cone distortion
One of these three will be your issue.
Also, you may remove the speaker and leave it hanging with the wires attached. Knowing that no wiring is shorted and nothing is disturbing the cone, try running your stereo. Same crackling problem? It may be an impedance issue or you reversed the polarity on your speaker.
It will require some work but the solution is there if it was working before.
Apr 12, 2011 | 2003 Chevrolet Impala
Static crackle on yamaha 6030 in 5.1 ..static dissapears if you switch to two channel. coming from bell hd pvr...and sony ps3. with ps3 i have to select audio from dvd or blu ray menu and then 5.1 and...
It might be a bad connection then. First try and swithch it to a different outlet and settings. If it does not work it mightn have to be fixed then.
Mar 28, 2010 | Yamaha HTR-6030 Receiver
System shuts down when playing music dvds at 17 or 18
Check your speakers one by one, maybe one of them are about to burn that´s the reason your device turn on protection state,good luck
Mar 16, 2009 | Televison & Video
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
No sound coming out of back speakers when watching DVDs
Make sure you have set blu ray player out put to bitstream,if you have set to pcm for hd master audio and dolby true you need to have a amp to decode this and hook up with a hdmi cable.If your amp has hdmi in and out but no high def audio you may still get multi channel audio.
Hope this helps.
CABLE GUY.
Mar 06, 2008 | Yamaha HTR-5790 Receiver
Feedback from spekers
suggest,checking pwr point earth,power leads, try a different antenna,unplug any external connections not needed to recieve broardcast,shift position of tv by 3 mtrs. Regards Chook.
Apr 01, 2007 | LG DVD 5253 DVD Player
Durabrand 5.1 Surround Sound Computer Speakers Logo
79 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
