Question about George Foreman G5 Indoor Grill
Odor When the grill is hot the plates give off an odor/smell that is almost noxious
  • Anonymous Nov 23, 2008
    probably not terribly safe, but after using it several times, it doesn't smell so much.....
  • 368 Answers
Hi Sunlark,
I'm guessing your product is new -- the first couple of times you heat the elements, they're going to cook-off any chemicals that might have been on the plates as part of the manufacturing process. This may include any non-stick chemicals that might be bonded to the surface.
I personally try to avoid non-stick products as I'm leery of the Teflon/fluorine in the product, but I'm told I'm a little paranoid about things like that - - you have to use your own judgement.
If this smell persists after the first several uses, I'd contact the manufacturer's customer service people.
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Posted on Dec 30, 2008
ODOR OF NEW OVEN
this is normal as after manufacture these units are stored before shipment and they put a coating on the elements and bake racks so they don't rust during storage
Dec 10, 2012 | GE JGRP17 Gas Single Oven
Tip
Bad odor in refrigerators...
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
  1. Keep an open box of baking soda inside the fridge it will absorb the foul smell.
  2. Place newspaper made into balls all over your fridge and freezer so that it is completely covered.Spray the newspaper with water until it is completely wet.
  3. Allow the fridge to run as normal for five days. During this time, the combination of evaporating water and paper will soak up the nasty smell. It should be noted that you will have to turn your freezer to the lowest setting to avoid getting frozen.
  4. Buy some freshly ground coffee.Dump 1 to 2 cups of the coffee grounds on a large plate and spread them around. Use multiple plates if the smells are extreme.Place the plate on the center shelf.Close the refrigerator for 24 to 48 hours.Dispose of the coffee grounds.
  5. Cut a lemon in half and put it in there - it will absorb the smells and make it clean smelling.
  6. Last but not least ....Empty contents of fridge wipe out with warm water and a little lemon juice then cover a tray or plate with kitchen foil and fill with charcoal put in fridge over night and the charcoal absorb es all nasty ouders then in morning remove plate or tray.It should have no smells at all.
Thank you for this opportunity t post few tips which i know. I think all the above are home made tips and anyone can try it out who are facing the problem of bad odor in their refrigerator..
on Oct 18, 2009 | Kenmore 50522 / 50524 Side by Side...
New, Hot & Smelly
If it is brand new you should return it.That is not normal!
I would not take it apart or try to repair it in any way because if they see that you have taken it apart they will it will void the warrantee
Sep 17, 2012 | Eureka 431A Optima Bagless Upright Vacuum
Foul Odor
Odor from the water softening system can be attributed to several causes.
The best way to see if it is coming from the softener is to by-pass the softener and run the COLD water only for several minutes and see if the smell continues. Now run the HOT water and see if smell is coming from the water heater.
Some causes may be:
1. Hydrogen sulfide in the water supply (the water chemistry can change)
2. Sulfate reducing bacteria. Almost all water supplies have sulfates and if bacteria gets introduced into the plumbing system it acts with the sulfates to create sulfate reducing bacteria. Which creates a rotten egg smell in the water.
3. Salt additives can have many different affects on water chemistry and organics in the water causing musty, fishy, swampy type smells.
4. If you have a system for Tannins using salts with additives will always cause foul smells as it harms the Tannin media.
5. The ANODE rod in the water heater degrades and gives off a sulfur type, rotten egg smell.
RJ
Jul 22, 2010 | Culligan Under Sink Water Filter
Burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
Aug 28, 2009 | GE Refrigerators
Odors of other cars come in
The only way to mask odors from other cars is to place your CLIMATE CONTROL SYSTEM on RECIRC. This will re-use internal cabin air rather than take in FRESH OUTSIDE AIR, polluted with noxious odors. Hope this helps.
May 06, 2009 | 2004 Ford Explorer
Pervasive chemical odor
I was just recently having this problem myself (and I'd also encountered it long ago as well). Fortunately, I live in an apt. for the time being, so it was exchanged with another fridge after persistent complaints to the management. However, I did do a little sleuthing before the exchange ... and I did read something online where someone said (and pretty definitively too) that oftentimes "chemical smells" occur as a result of a coolant leak. Despite the fact that I did not physically see a leak, this explanation still made the most sense to me given the character of the smell.
So, your problem, like mine, is more than likely caused by an internal, occult leak. Also, not to worry you, but I would advise you not to consume anything else from your fridge/freezer until this is resolved since your food is being constantly permeated with this noxious gas circulating around it (and yes, even through the containers' small crevices). I ended up pretty much throwing out everything :( I am an RN, BSN by the way - we nurses usually have some pretty sound advice (even when it's bad - sorry).
Apr 28, 2009 | Kenmore Refrigerators
I can smell gas even though the grill is working
One of the valves is probably not closing all the way on grill. Leave griil alone with LP turned on for about 5 minutes and walk away for 5 min. and come back and see if you still smell a strong odor. If LP odor is still strong turn of for a couple of minutes and open grill hood to vent. After a couple of minutes bring a hand held bbq lighter to test burners to see if any will light with LP on and grill valves off. If any one of the burners light, that should determine which is bad and needs replaced. (Order one off Manf. website or return to store you purchased grill from.)
Otherwise if none light, replace the rubber gasline(might have a leak) and the regulator w/tank connection(might have gone bad). You can aquire a universal one at most grill stores or a Menards, or internet.
And the there's always getting the LP/propane tank and valve checked out at a filling station, to be sure there is no damage.
Good Luck, hope this helps.
Mar 21, 2009 | Weber Genesis Silver B Grill
Refrigerator Smell
remove grill. pan will not come out ( leave it in place ) took an empty liquid dish detergent botlle of bleach and water squirt into pan let it sit - scape if needed . then take a wet/dry vac - repeat)
I will let you now if the odor is completely gone
Oct 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Burning odor
REPLACE POWER CORD ITS MOST LIKELY WORN BY THE HANDLE WHERE THE RUBBER BOOT IS
Sep 30, 2007 | Kenmore Deluxe KSR400 Iron
George Foreman G5 Indoor Grill Logo
563 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
