Question about LeadSinger LS-3000 Consumer Microphone
LS 3700 Leadsinger Microphone
Our new microphone LS-3700 (as well as an older LS-2100 series microphone) does not project thru the TV speakers. We meticulously followed ALL the troubleshooting procedures by the manufacturer-- LEADSINGER with no luck. We even switched TV sets. The video and sound are working fine, but the program does not recognize the microphone. HELP!
  • rosiesdad Dec 09, 2008
    My LS-3200 mic died. No sound. The sub mic still works. Leadsinger said to send it back to them. Now they don't respond to me and their service email bounces back as "Undeliverable". DON't buy from leadsinger!!!!!!!!!!
  • Anonymous Mar 26, 2014
    leadsinger ls-3700 does not turn on when power is pressed.
We had the same problem just this weekend. However, we investigated it ourselves and discovered that you can take the microphone apart by unscrewing the two small screws inside the mic, under the music chips. Once the screws are out pry the two halves apart very carefully. Once we were inside, we discovered that the soundcard was loose and all we had to do is plug the sound card back in. Close 'er up and start up the show. Good Luck!
Posted on Dec 23, 2008
My leadsinger ls-3700w no sound
Posted on Sep 12, 2010
Leadsinger 3000 series
throw it in the garbage. its a trash.
Apr 06, 2009 | LeadSinger LS-3000 Consumer Microphone
No sound coming from wireless mic
check the battery, if dead replace new. check the switch might be a cold solder or loose wire and finally check the condenser mic by placing a multitester to the two connectors of the mic with one wire from the mic desoldered. if there's a continuity, then its good. if there's no continuity the mic condenser is busted. go to radioshack and find replacement mic condenser.
Mar 28, 2009 | LeadSinger LS-3222 Consumer Microphone
Leadsinger microphone..... no sound on tv ..microphone seems dead
Did you go to Leadsinger.com and follow their instructions on doing a Hard Reset? It might help. I had the same problem but with a scrambled picture and no sound. The reset restored the picture but not the sound. Thats when Leadsinger returned it for a reconditioned one that worked worse than the first one. Now I get no response from them.
Feb 26, 2009 | LeadSinger LS-3000 Consumer Microphone
Downloading
you could have downloaded a different format. try to read the manual of your karaoke, look what kind of format used, then download the same format.
Dec 26, 2008 | LeadSinger LS-3222 Consumer Microphone
Cable conexion is broken
I removed the cable from microphone circuit board  and shortened cable by 20 cm. to eliminate damaged wires, stripped the individual wires and soldered the pins to the new wire ends and reassembled.  Used black heat shrink tubing  [10mm dia.] to reinforce cable end at mic to prevent future damage from careless handling.
Document wire colours to pins before disassembly
Red                   Audio L
White                 Audio R
Blue                   DC Power
Shield [ground]     Ground
Yellow                 Video
Dec 13, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
Leadsinger sub mic, modle LS 3222. Green lite flashing but no sound. any help?
We had this problem too. Can you perform any functions with the duet mic? We couldn't, just had the light flashing. Turns out the light is supposed to flash (never is solid). Check the connections to the sub mic pack in the back of the main mic. Ours was loose. Once that was plugged in properly, we turned everything off and started again. All was fine.
Good luck.
Nov 29, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
Magic-Sing EG-18000 works, no sound
look and see if the RF light is coming on, if it is not then the transmitter (mic) is not on the same frequency as the receiver.
Nov 22, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
LeadSinger LS-3000 Consumer Microphone Logo
1,158 people viewed this question
Top LeadSinger Audio Players & Recorders Experts
Michial Gueffroy
Shehu Pro
Shehu Pro
johnny rebel
Are you a LeadSinger Audio Player and Recorder Expert? Answer questions, earn points and help others
