I have a top loading Frigidaire washer that won't drain
    President:
  • Washing Mach... Master
  • 2,651 Answers
Either the lid assy is not functioning correctly ( the machine will not spin if it doesnt think the door is down, or there is something stuck in you drain pump assembly
Posted on Nov 10, 2008
Will not drain
FRIGIDAIRE TOP LOAD WASHERS WILL NOT SPIN OUT WHEN THE LID LOCK IS BROKEN
Mar 20, 2014 | Frigidaire FWS833A Top Load Washer
Frigidaire Washer/Dryer Combo FEX831CS0 won't work
Hello Laura Clark - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Since it is such a complex unit, I suggest contacting a professional to move forward accurately
Dec 12, 2012 | Frigidaire FEX831CS Top Load Stacked...
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
My frigidaire affinity pauses during the cycle and won't drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Washing Machines
Washing machine won't drain
heatman101
May 14, 2011 | Frigidaire Washing Machines
Frigidaire Top Load Washer
Hello vohra_sam
welcome
You said , Water will not drain out
Usually this is the answer
Water in washer does not
drain or drains slowly.
Because drain hose is kinked or clogged.Clean and straighten the drain hose.
let me know, Huuum
Sep 08, 2008 | Frigidaire GLWS1339CS Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
