Question about Optoma EP716 Multimedia Projector
Optoma ep716 I have an optoma ep716 projector and when I first turn it on, it plays fine for about five to ten minutes then the picture turns green first then a red light comes on then it shuts off. I have purchased 2 new lamps and it still does the same thing. What could be the problem please help
  • kenmyla Nov 10, 2008
    Same problem
  • rysialanae Dec 19, 2008
    Well I figured it out what the problem is, the fan that keeps it cool stopped blowing so I purchased a small fan just for the projector. When I turn the projector on I turn the fan on to keep it cool. It was just overheated. So thanks alot for trying to help. A little $24 fan has saved me alot.
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Posted on Dec 18, 2008
Why does my optoma ep 759 projector will not turn off and the stanby green light is blinking?
Try holding the button for ten minutes and then maybe it will turn off but then it will fall off ha ha
Mar 15, 2015 | Optoma Office Equipment & Supplies
The screen turn green on my Optoma TX1080 DLP projector what is the problem
Usually, that means that there is an issue with the cable connecting the computer to the projector. Check to make sure none of the pins are bent or broken. Aslo see if a differnt cable works correctly.
Nov 18, 2014 | Optoma TX1080 Projector
I neet a colour wheel for an EP716 and calibration instructions. thanks
My 716 when I turn it on after 3/4 minutes the images turn green and then it turn offf
Mar 22, 2011 | Optoma EP716 Multimedia Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
Optoma projector Ex350 connect to xbox360
buy a new projector i recommend sanyo projector specially model XT35... cause your projector is not compatible to your xbox.
Oct 06, 2009 | Optoma EP716 Multimedia Projector
Optoma ep716 loud noise
the colorwheel needs replacing. the bearings are shot.
Jul 25, 2009 | Office Equipment & Supplies
Optoma ep716 continuous loud vibration noise when turned on.
the fan motor could be failing. turn it on with the top off. if one of the fans is moving slower, that'd be the one. since this is a dlp projector, the colorwheel motor berings might be on their way out as well. both need replacement.
Jul 25, 2009 | Optoma EP706 Projector Remote Control
EP716 Optoma Projector Fuse
There is no fuse. I took my EP 716 apart to find out why it died. I found a resistor had blown on the power board made by the Tiwan co. Quazarpower.
Dec 11, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716 turns on but no picture displays
Don't ever just unplug the power cord while it is on. The bulb needs to cool down with the fan still on.
Did you ever connect a source?
Sep 17, 2008 | Optoma EP716 Multimedia Projector
Optoma EP716 Multimedia Projector Logo
385 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
