Question about GE Profile Harmony DPGT750EC Electric Dryer
My GE Profile Squeeks
When it is on it makes a squeeking noise however it still works.
  • jnux2 Nov 18, 2008
    terrible high pitched squeak
Yes it still squeeks and it still drys and it kinda stops being so loud after the dryer has been drying for some time. Need help on solving this iissue and how to fix it.
Thanks,
Elaine Mohr
Posted on Nov 19, 2008
Have a G.E. DRYER PDVH515 . It squeeks, roughly on every rotation of drum. Not a consistant long noise.It's been going on for some time now so wondering if greater damaged may be done? Thankyou
The sound is most likely from the rear drum teflon bearing failing. It may also be the front teflon glides. Or both.
The problem is not going to get better and will gradually get worse. You won't do any real damage if you continue to use the dryer.
However, if the sound stops being a squeak, and sounds more like a grinding, metal to metal sound, stop using it and call the repairman.
Mar 10, 2013 | GE Profile Wizard DPSE592EAWW Electric...
My HL 2140 squeeks loudly when I turn it on as well as when it is printing
it most likely has parts that are worn out and need replaced. you will need to have it serviced.
Oct 09, 2012 | Brother HL 2140 Laser Printer
Squeeks loud
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 25, 2010 | GE Dryers
Squeeks and creeks from the front right wheel on my honda civic
you could have 2 problems. steering leak and poss a bearing. jack up the car and spin the right front wheel, makes noise there is a problem. if the noise only happens when you turn, with tire off turn the wheel and watch.
Mar 06, 2010 | 1997 Honda Civic
Elec. dryer squeeks...squeeks...squeeks...replaced belt, did not improve. Could it be the plastic drum slides, I only say this because they look really worn?
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your rollers for flat spots, if they have flat spots on them replace them.
If the rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 10, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Squeeks loadly when running
The drum belt is slipping or a support wheel bearing is worn.  Spray some belt dressing on the belt or replace the belt.  Lubricate the wheel bearing or replace it.  It is also possible that the seal between the drum and the housing (at the back) is worn and the drum is rubbing metal-to-metal on the housing.
May 28, 2009 | GE Profile Harmony DPGT750EC Electric...
Constant squeeking while drying clothes
It's most likely the roller bushigs/axles which need lubricating -- they've probably not failed yet, but will if ignored.
They squeak more when clothes are wet because of more weight.
I'd also lubricate the motor while your in there.
May 08, 2009 | Dryers
98 Ford Ranger Squeeks when accelerating
do you hear the squeeking in the truck only if so then its the little o ring plastic in the peddle makeing the noise.
Feb 04, 2009 | 2003 Ford Ranger Regular Cab
GE Washer WPSQ4160T
TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
Dec 07, 2006 | GE WBSE2090A Top Load Washer
GE Profile Harmony DPGT750EC Electric Dryer Logo
330 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
