Added a hard drive to my son's computer, reinstalled the OS, went to put the video card back in and I don't get any thing. the only visual I get on the screen is a little box that says no signal. I have tried removing the video card and going back to the standard one and it still does nothing. System: Dell Dimension 4600 OS: Windows XP Professional Video Card: Ati ALL-IN-WONDER® 128
    Genius:
  • 1,124 Answers
Which card you were using when installed the OS?
Are your card seated properly?
Is the new card compatible with your motherboard?
Is your memory properly seated?
Posted on Nov 10, 2008
My os system is windows7 home i have a verbatim model #is320 usb i would like to un partition this drive make it one drive for my music files thank you
i don't think if we could do it using a third party application, this might put your files in risk. best thing we have to do is to back up all your files and do a reformat. and reinstall windows again. for safety purposes.
Jul 12, 2011 | Verbatim 320GB USB Portable Hard Drive
My HP G70-258US (Vista OS) hard drive will only run the computer in Safe Mode. The drive has failed the S.M.A.R.T. I have replaced the drive. After reinstalling the HP software on the new drive and...
i would advise a different os than vista but you can put the old hard drive back in run it in safe mode and by a cheap external hard drive case and transfer the files for the operating system to the new hard drive and then switch the drives back out
Mar 25, 2011 | HP G70-250us Notebook
Lan card is not detected in dell gx240
Hi, I have the same model dell.
Here is a link for the driver for your pc.
.http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PLX_PNT_P4_GX240&os=WW1&osl=en&catid=&impid=
Just select networks, and you'll see one that says 3com driver.
This is the file that is needed to make the lan card work.
I had to reinstall most of the drivers on mine, as it was an old school computer that had SEVERAL viruses, and by the time I had gotten rid of al of them, about 2/3 of my operating system was gone. I had to use another computer to download a copy of xp home w/sp 3 just so i could power the darn thing back up.
Then I had to manually reinstall every driver on the computer, as well as update the bios, replace a hard drive, upgrade the ram, because they had left it with only 32 mb of ram, not even enough to boot up with.
Now I have 512mb ram, 2 hard drives, a dvd rom drive, and advd lightscribe burner.
I also opted to replace the factory ati video card with dvi output, mainly because i didn't have an adapter to work with regular vga monitors. So i put an old nvidia fx5200 pci video card in.
Now it runs like a champ!
I hope the link I provide works for you., Good luck, and have a good day.
Jan 28, 2011 | Dell Ethernet Card Network Adapter
Hi, I purchased a acer on 8/20/10. Updated with a new video card on 9/9/10. Worked great until 10/3/10. I was playing a game and the computer froze. I had to do a hard shut down. Computer came back up,...
Hello sir, if your hard drive and video card is new for now, then maybe your memory card is not enough for your PC. And please try to check the processor because I encountered some problems like that.
Oct 08, 2010 | Computers & Internet
Black screen on Vista reinstall
make sure you have only one video card installed check bios for the video card.. try vga..if expansion video card is installed...remove it and use the internal to check if it works..
Dec 30, 2009 | Microsoft Computers & Internet
I used killdisk to clean my hard drive and now i get a pbr error
Let's hope you didn't. You might have to completely reinstall the OS. Disconnect everything from the computer except the hard drive and master DVD or CD, keyboard, and mouse. Disconnect even the ethernet cable and external devices. You might even take out any extra cards, everything you can. The idea is to eliminate any possible conflict. I'm not sure you have the right idea on Killdisk use, I only use Killdisk to wipe clean the hard drive to reinstall, and I still had problems. The only way to get this to work is to eliminate all possible conflicts. You may even have to go back to the original BIOS. Do that very last if still having problems.
I ended up putting another OS copy on. If you put the original OS back on you can try the hard drive you have but, you might have to use a brand new hard drive. I think that was my hang up. Killdisk can't get the last bit of information off. But, I think it may have worked if, I would have eliminate all conflicts like I have informed you to do.
Oct 29, 2009 | Dell Computers & Internet
Can you Recover deleted video off the camcorder?
I have had success with this camcorder recovery software named asoftech data recovery... Download the program
http://www.asoftech.com/adr/
Please be noted that your camcorder memory card/hard drive should show as a drive letter in your explorer, if not, you need to take out your memory card or hard drive and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Mar 02, 2009 | Pure Digital Flip Video Camcorder
Boot up problem
youre hd needs an os installing on it.first partition,then format ,then install os(windows)
the system is looking for a os not a hd ;the beeps indicate no os found(no drive by default)
if there is no hd,memory,or video card or stuck key the pc will beep.also with video card not connected the screen will be blank also with many models no memory will result blank screen.In ur case its only the hd.make sure all items are fitted insert os disk in cd drive start pc and boot from cd,to create partition,format and install
Mar 04, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
David Payne
David Payne
