Question about RCA HD52W56 52" Rear Projection HDTV
Crazy menu, comes on periodically without using remote
My 52 RCA rearprojection TV is 5 years old. Has been running well until the last few weeks when I changed the remote batteries. I have an aftermarket remote that has worked flawlessly for the last 2 years. now, whether there are bats in the remote or not, the menu comes on uncontrollably and the remote no longer controls the tv. even when I turn it on using the front panel buttons the menu will not turn off. the tv can not be used at all without the menu coming on. !!
Believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Posted on Mar 18, 2007
I have an RCA 52 " projection TV thats now 6 years
you have to run theater system eather through your vcr or your dvd player for mor out put jacks and input jacks on older tvs but the thing is your dvd player remote will be your tv remote the same as your vcr remote.
Feb 13, 2011 | RCA P52937 52" Rear Projection Television
Lost picture
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a GE 52 " rearprojection flat screen picture TV 4 years old. The color conveyance is off and it will not realign using the remote. Help!!
If the convergence option is still visible under the picture settings in the menu. Then the problem will usually be related to the convergence power supply board, which is the board on the far left which is suspended over the main chassis. You can get the convergence power supply board, or have yours repaired at www.tvrepairworld.com
Nov 29, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE 52 " rearprojection flat screen picture bowing 3d effect
Thats usually a very easy repair by replacing FL231, DL231 and CL230 total parts are about 11.00 at the following link and they provide free instructions. The components are all listed under RCA parts category.
http://servicemanuals.vstore.ca/
May 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Rca r52wh74 - no auto convergance
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
RCA 52" Menu Keeps Popping Up and Down
I see this alot at the shop ... the front panel buttons have become damaged. THe best coarse of action is to replace the front button cuircit board assembly... **** there is a tempery fix untill you get the part... remove the front panel and take button cuicit board out...just use remote to control the tv. This is also a way to test to see if this is the problem.. if you romove the connector to the buttons and the problem goes away then the buttons are the problem. you get get this cuicit board at union electronics. You have to get the extended model number off the back ussally d52w20yx1 or yx2 or yxsomething...not to difficult a repair
Nov 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca 52 inch hdtv turns itself off after a few minutes
Sounds like the green tube shorting intermittantly. Have a qualified tech use a tube restorer to check for shorts, or the loss of the 300v line to the green tube.
Aug 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung LE26R73BDX 26INCH - LOSS OF DIGITAL SERVICE
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Dec 28, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
163 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
