Question about Onkyo TX-SR605 Receiver
Onkyo TX-SR 606 KEEPS CLICKING INSTEAD OF TURNING ON WHEN POWERED
My Onkyo receiver won't turn on. When I power it, it just keeps clicking. Any suggestions. I don't think there is warranty, bought at auction
  • schreckairfo
    schreckairfo Sep 10, 2012
    I have the same problem now, did you ever find a solution??
  • Anonymous Mar 22, 2014
    there were some clicking sound, and video flash. now no power
    Problem Solver:
  • 16 Answers
Here are your options:
1. An electrical problem, where your receiver has a grounding problem.
2. Your speaker wire connections are actually touching each other and that's why your receiver is not turning on.
Posted on Nov 15, 2008
The TV turned off and will not come back on
keep your reciept throughout your warranty period.
Dec 17, 2013 | Element Electronics FLX2211B 22 in. LCD TV
My Onkyo TX-SR606 won't turn on
The reference to Zone 2 means that your Onkyo receiver is set to be remotely controlled from another location. Normally, this arrangement would be initiated at the time of set up but could be done later. You may have to repeat the initial set up routine to get things back to normal
Feb 22, 2013 | Onkyo TX-SR605 Receiver
Hi, I have a 3 year old Onkyo TX-SR506 receiver that I bought secondhand. The receiver can get very dusty so I was cleaning the top with a damp cloth while listening to music. Suddenly the music stopped...
I don't think its a harmless coincidence that it happened while you were touching it.
Assuming 'damp' means 'no dripping' I'd discount mositure as the cause. Was there something else you may have touched or caused to move during your actions, like speaker wires? Retrace your steps (with power off) and imagine what may have moved.
Disconnect the speaker wires at the receiver and see if that helps. If so, you just need to start adding speakers until it fails again or not, then isolate the cause if it is related to specific channel(s). If it doesn't come up 'naked' something cooked inside and a hands-on tech needs to get involved.
In the future - turn it off when manilpulating anything on, near or attached to it.
Jul 12, 2011 | Onkyo TX-SR506 Receiver
Onkyo TX-8011 stereo receiver only rt. channel works barely.
First of all verify that there is no need for a "shorting plug" on the back of the receiver. Look for Pre-amp IN and Amp-IN RCa jacks. These may need to be connected. Also verify that the tape monitor switch has not been engaged. This too will result in only hearing crosstalk when the volume is all the way up. Update this with your results and we'll continue from there if the problem remains.
Thanks,
Dan
Dec 18, 2009 | Audio Players & Recorders
When I first turn on the receiver in the morning to watch TV, (ATT Uverse), I get an error, "No Signal." After about 10 minutes, if I switch the input on my TV, then go back to the correct input, it...
if you are using hdmi cable, you should switch to using component cables for the video - (red/blue/green) - you will need to use the white/red for your sound (or the optical cable) - uverse is aware of the issue and if you call they probably wont be able to send someone out but they can give you a credit for buying the cables
Aug 30, 2009 | Onkyo TX-SR606 Receiver
8omh reciever and 6omh speaker
HI,in the speaker set up menu on your amp there should be a 6ohm setting but if not don,t worry as it won,t cause any problems.You will have to set the levels for your speakers so they match each other to keep sound right.
HOPE THIS HELPS.
CABLE GUY.
Aug 03, 2008 | Onkyo TX-NR801 Receiver
Receiver keeps turning off after I turn it on.
CHECK THAT YOUR SPEAKER CABLES ARE NOT TOUCHING.ALSO DID YOU NOTICE THAT THE SPEAKER CONNECTIONS ON YOUR 605 ARE SIDE BUY SIDE NOT ABOVE EACH OTHER?
Jun 02, 2008 | Onkyo TX-SR605 Receiver
HT-R510 home theater system
If bought new return immediately for replacement. The amp section is no good and cannot be reset - needs repair. but you are under WARRANTY - use it.
Sep 06, 2017 | Onkyo HT-S490 System
Onkyo receiver problems
All speakers and lines OK?  Sorry for basic approach!!  Protection is supposed to work when speaker outputs are loaded under recommended Z. speaker Z is a setting too ... along with several other paramenters.  Also, re the "last return" ...  Maybe the back surround speakers were turned off in settings?  Again, apologies if you've tried all this basic stuff.  I've just bought one of these amps and have probs with the FM tuner not tuning anything.  Mmmm. Back to the shop??   Cheers, Chris
Oct 03, 2007 | Onkyo TX-SR503 Receiver
Onkyo TX-SR605 Receiver Logo
1,069 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
