Problem with my dvd player
When i put cd in my dvd player it says on the screen no disck. and i can hear a nosie from inside the dvd player as if the disc is spining.
by the way, this problem occur after i took a cd that was stuck in the dvd player and since then i am not able to use my dvd player. can you help me please.
many thanks
  • 153 Answers
There should be a cable connected from the main circuit board to the lens which powers up the lens laser beam to read the disk presences to spin. It might be disturbed while you are trying to remove the disk that was stucked. try reinserting it and be careful not to damage the lead connectors. cheers.
Posted on Nov 10, 2008
DVD Bypass Codes w/ NO SWITCH
1- put dvd inside the video player
2- wait for blue screen to pop up and you should hear music begin playing
3-press stop twice on your remote
4-enter the code 26604
Dec 19, 2012 | Dual Xdvd8181 Cd/dvd/mp3/wma Motorized 7"...
When i put a dvd in it ejects it out and says bad disck
Im assuming the disk is not scratched that bad? Every few months I buy a CD/DVD cleaner and use it for my car stereo. It makes its laser much stronger to read Cd's/DVD's.
kc
Mar 09, 2011 | Car Audio & Video
New Memorex Dvd player put in disck says no disk in player
Make sure to try it with an unscratched "normal" DVD (NOT HD-DVD or BluRay!)
Also, make sure it doesn't want the DVD inserted upside-down...
Oct 22, 2010 | Memorex MVD2050-BLK DVD Player
My Phase Linear UV7il accept only some CD's
the head unit is not reading due to incompatibility with thebrand or type of disck
Dec 29, 2009 | Car Audio & Video
A blank screen someone pushed something and messed my laptopup.
The computer ask for a botabile DISCK something like recoverry disck or a windows setup, put the recovery disck in the cd-rom/dvd-rom and set bios to boot from DVD/CD-ROM and falow the setup instruction.
Feb 26, 2009 | Acer Computers & Internet
Dvd player only plays some movies
it might be sevral reasons:
1. Check if region code is the same for movies you playing and DVD player
2. If you using video CDs or copyed DVDs, player might be preventing to playback those kind of discs, due to copyright laws or due to different speed settings for DVD player and discks you using (for intsrance you player can playback DVD/CD+R, and you using DVD/CD-R, or mximum allowed playback speed is 16 you using disk recorded at 24, but this is in case you using burned/copied CD/DVDs)
3. Check it lens is durty. For that use CD/DVD lens cleaning disk
($6 in Walmart, if you are in US)
4. Check if movies you are have the same coloring system, i.e NTSC for US
5. Check CD/DVD for scratches, some DVD players can not playback scratched disks
Please kindly let me know if my information was helpfull for you or you need more info
Good Luck
Feb 01, 2009 | Philips Magnavox DVD/VCR Dual Player
When i put cd in my dvd player it says on the screen no disck. and i can hear a nosie from inside the dvd player as if the disc is spining. can you please help me. many thanks
1-First check the motor by measuring the resistance,it should read between 10.5 to 13 ohms or above
2-check the lense if its emitting light and dvd cable continuity with the meter.
Nov 04, 2008 | Televison & Video
Screen is blank
Check to see if the little button that the screen closes down on (which turns off the screen and only the screen) is stuck, or jammed under the little hole that it comes up.  This button is about the size of a pin on most DVD Players, and is located very close to the screen on either side.
Jan 03, 2008 | Mintek MDP-1030 Portable DVD Player
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
