Question about Epson CX8400 All-In-One InkJet Printer
Cant print When i turn on my printer it is already in copy mode. I just want to print a document from word. With the document open I click to print and the printer screen says printing, the paper is pulled through the printer and the ink cartridge is moving as if to print however, it comes out completly empty. I don't know what to do.......I did check the ink levels and there is plenty of ink.
    Genius:
  • 1,447 Answers
Hi
Uninstall the driver, go to support.epson.com and download the latest driver for your printer.
Hope this helps
Posted on Nov 14, 2008
I dont know how to prtint
here are some steps to print document.(just make it sure that your printer is properly installed in your computer.including the printer driver.
1. 1
Open a program that allows you to insert text into a document or get on the internet.
2.
If you were to open a program, you would need to type text into the document. If you were to get on the internet, you could skip to step 7.3.
After you have typed text into the document, you need to locate the menu bar, click on file, then point to print.4.
Click on print.5.
When the print dialog box appears, select the printer you want to use (if it is not already selected) and select the number of copies to print.6.
Click OK.
7.
If you were to print a page or pages from the internet, follow steps 3, 4, 5, and 6, except you don't have to type text into a document to print.
Sep 23, 2011 | Office Equipment & Supplies
What button to press to copy a document ?
If you are putting a document into the printer and want to make a copy of it, press the key that says "copy" on the printers keyboard. Then choose the number of copies you want to make and press the "ok" or "enter" key on the keyboard of the printer.
If the document you wish to make a copy of is located in your computer and you dont have a copy of it to place in your printer - then you need to print the document. Not copy the document. Copy means make another one. You can't copy something that you dont have in your hands. Understand? To print a document that you dont have in your hands, find it on your computer. When you find the document you want to print on the computer, click on "file" in the upper left side corner of your computer screen and slide down to "print" and click on it. Then click on "ok" on the next screen to start printing your document.
If there is no "file" command in the upper left corner of your computer screen when you have the document that you want to print open on the computer - try right clicking with the button on the right side of your mouse in the center of the document and find the "print" command on the drop down list and click on it. Then click on "ok" on the next screen and this will start the printing of your document.
Hope this helps? Good luck!
Jul 07, 2011 | Office Equipment & Supplies
Keep printing old docoments / will not print current docoment / printing seem to be strunt
Follow these steps to fix your problem :
Method A :
Press the cancel button or use the cancel menu command on the printer
The most obvious way to cancel a print job is to find a cancel button or a cancel menu command on the printer and to press it. So, if you have not already done this, try this method first.
If this method worked for you, you are finished with this article. However, you may want to read the "Prevention tips" section to avoid this problem in the future.
If your printer does not have these items or if this method did not work for you, try Method B.
Method B:
Turn the printer off and on
Next, try turning the printer off and then on. With certain printer models, this cancels the print job.
If this method did not work for you, turn your printer off, and then try Method C.
Method C:
Use Control Panel to cancel printing
This method is a bit fancier. We will use Control Panel to try to cancel printing.
But what exactly are you trying to do? Are you trying to cancel printing only a single document, or are there other print jobs that you want to cancel? And are all the print job yours, or are there print jobs that other people have sent to the printer? If you have to cancel documents that other people have sent to the printer, you must have Computer Administrator status or you must have permission to cancel the print jobs. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
* To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
* To cancel all print jobs, click Cancel All Documents on the Printer menu.
Note If you cancel a print job that you did want to print, make sure that you send the print job to the printer again.
If this method did not work for you, make sure that your printer is turned off, and then try Method D.
Back to the top
Method D: Stop the print spooler and delete all spooled files
If you tried Methods A through C and you were not successful, Method D should work for you. If you came to Method D immediately only to delete a print job, some of what we say here might not apply to you, so please bear with us.
Method D is somewhat more complex and will require a bit more work than the other methods, but don't worry. Method D looks much more difficult than it really is.
First, in case that you don't know how printing works, here is a short explanation. Print jobs are sent to the printer as spooled files. This means that the files are put in a temporary location so that the printer can access a print queue and print jobs at its own speed. If you stop the spooler and its files, most of the time, you both cancel printing and delete the print job.
Note To use this method, you must have Computer Administrator status. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
Step 1: Start Notepad
To stop the print spooler and its files, we will have you create and run a script file that will automatically stop the service. This sounds difficult, but it really isn't. Just follow these steps carefully.
2. In the Open box, type notepad, and then click OK. Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
Now we will have you copy and paste some commands to the Notepad document.
1. Carefully select (highlight) all the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
2. Right-click the text that you selected, and then click Copy.
3. In Notepad, right-click in the blank document, and then click Paste.
4. Carefully select (highlight) all the following text:
C:\DeletePrintJobs.cmd
5. Right-click the text that you selected, and then click Copy.
6. In Notepad, click Save As on the File menu.
7. In the File Name box, right-click, and then click Paste.
8. Click Save.
Step 3: Run the command script file
Now that you have created the command script file, you will run it. To run it, you will copy and paste the name of the command script file in the Run box.
3. Click Start, and then click Run.
4. In the Open box, right-click, and then click Paste.
5. Click OK.
6. Notice that the Command Prompt window opens to run the command script file that you created. Notice also that this window closes automatically when the command script file has finished running. If you do not see the Command Prompt window open, check that you saved the command script file by using the correct name and that you entered the correct command script file name in the Run box.
If this method does not work the first time, or if you cannot print anything after you use this method, restart your computer, and then try again.
Nov 20, 2010 | Lexmark X2500 All-In-One Printer
How do i cancel a print job?
Method A: Press the cancel button or use the cancel menu
loadTOCNode(2, 'resolution');
Method B: Turn the printer off and on
Method C: Use Control Panel to cancel printing
printing.
steps.
    • To cancel individual print jobs, right-click the print job that you want to
    • To cancel all print jobs, click Cancel All
If
future.
files
us.
it really is.
print job.
loadTOCNode(3, 'resolution');
    net stop spooler
    del
    del
    net start spooler
    File menu.
    then click Paste.
    Note Notice that
    this file name differs from most other file names that you might have seen. That
    is because this file is a command script file.
  8. Click Save.
    click Paste.
  5. Click OK.
    Run box.
Note If this method does
Oct 08, 2010 | Pitney Bowes AddressRight DA300 Printer
I have a Canon Pixma MX330 color printer. It gets used only occasionally, usually to print brochures and the like. I recently switched it to copy mode by pressing the "copy" button on the front; now it...
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 05, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP 6200 without telling it to print, feeds and jams continually
I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
try this tip if acceptable of your situation now.
only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
and then, open a new documents page set up if needed.
and then print it without saving your file because that already save.
Dec 05, 2008 | HP Officejet 6200 All-In-One InkJet...
Printing documents backwards
You must have set it to be a mirror copy in the print settings.
Oct 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
My Hewlett Packard OfficeJet 500 was faxed a 45 page document, which I accepted (by activating the "Auto Answer" button) and printed. Then, while I was briefly out of the room, a second copy of...
I went back to Control Panel, and, following a hunch, found my way to discovering that the printer had somehow gone into "Pause" mode. I then simply clicked on the word, "Pause" and it converted to "Active."
Aug 15, 2008 | Office Equipment & Supplies
Changing Mode?
There is no way to change your machine into printer mode only. machine works in dual mode copier/printer.whenever you send a print from the computer, machine automatically receive the document and print it at the same time without changing the mode.like SCAN MODE AND HARD DISK MODE. So if you are facing a problem regarding printing then please check the paper size of the machine, and also check the paper size from the "PRINTING PREFERENCES" by taking the properties of printer icon in printer and faxes menu.(where installed printers shows) right click on the bizhub 200 printer icon and clickj on "properties". now click on "printing preferences" tab and then click on "size" tab, now from here check the paper size.its A4 or not if its not A4 then please change it to A4 then again give a print command.machine will start printing.
Jun 23, 2008 | Minolta bizhub 200 All-In-One Printer
Epson CX8400 All-In-One InkJet Printer Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
