Question about Garden
Chain saw i am not getting enough oil on the chain is there an adjuster i have the husqvarna 55 rancher
  • 211 Answers
Look at the bottom of the chainsaw.There is a screw(it has connection with the oiler piston).
best regards savumihai71
Posted on Dec 07, 2008
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
I have a rancher 455 and it's not suppling enough oil to the bar. Is there an adjustment for this?
The 455 has a 3 position adjustable oil pump, the adjuster screw is up under the crankcase, sprocket side, you need a flat blade screw driver.
Oct 11, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
I can not find a bar to fit the rancher 55. This
The 50/51 and 55 always had the same bar mount, the bar was part no. 508912164 for 15" 508912172 for 18" and 508912180 for the 20", the oil is not fed through the bar adjuster hole.
Aug 18, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
I have a husqvarna 55 rancher oil comes out the oil hole when bar is not on it but i put bar and chain on and it dosent get enough oil on chain just a small amount between teeth, ive cleaned bar and chain,...
The hole in the bar pad is the breather, it is quite normal for it to leak if the bar is removed, it consist of a role pipe and pipe inside the oil tank, there is nothing to worry about
Jan 19, 2011 | Garden
Chain oil leaks out quickly a rancher 55
Remove the bar and chain. Clean the engine side case where the bar fits. Does the oil port itself leak or is it coming from the engine case? If from the case, it may be a loose or split line from the tank or it could be a cracked oil tank. If the tank is cracked, replace it as there is no glue or epoxy that can permanently repair it. If the leakage seems to have stopped, clean the drive end of the bar including the two small oil passages that run out to the chain groove. Re-assemble the bar and chain, then run the bar tip at speed near some cardboard for a few moments--it should throw off a thin line of oil. This saw should have an oil volume adjustment screw located near the chain return area on the back or underneath the case. Adjust CW to reduce the oil volume. Hope some of this helps!
Jul 11, 2010 | Husqvarna Chain Saw 20" Bar
Turning up the bar oil?
An “OM, 455e Rancher, 455 Rancher, 460 Rancher, 2009-09, EN, FR, ES” Follows (may not be your saw):
An excerpt from page 38 of the above OM follows (forcing it may render it inoperative):
Adjustment of the oil pump
Adjustments are made by turning the screw using a screwdriver or combination spanner.
The machine is supplied from the factory with the screw set to position 2.
Turning the screw clockwise will reduce the oil flow and turning the screw anti-clockwise will increase the oil flow.
Recommended settings:
• Bar 13"-15": Position 1 (full CW)
• Bar 15"-18": Position 2 (center)
• Bar 18"-20": Position (full CCW)
These recommendations apply to Husqvarna’s chain oil, for other chain oils increase the oil flow by one step.
WARNING! The engine must be stopped when making adjustments.
All OMs and IPLs can be found here:
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Thank You for using FixYa.
Apr 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
What size file to sharpen chain for 55 rancher
It depends on the chain you have installed on the chainsaw. You can look at the numbers stamped on the drive link side of the cutting chain and it should have a 2 digit number that correlates to the size.
The factory chain supplied with the #455 rancher was a .325" pitch 3/8" chain.
Here's a link to the specs for your saw with some useful info
Hope you found this very helpful and best regards!
Aug 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
544 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
