Question about Refrigerators
Fridge stinks The Catch basin or whatever in the bottom is full and smells. Can't figure out how to dump it. I don't know how to detatch.
  • lamps28 Nov 17, 2008
    my fridge stink to high heaven. dont tell me to clean it as i have been at it for 3 hours. scrubbed from top to bottom with anti-bac stuff. drip trays cleaned and sterilised, drip tubes pipe cleaned. all trays etc removed and scrubbed and sanitised.
    still stinkkkssss dammit!!!!!!!
    help!
I just fixed this problem, and it was bloody disgusting. In my case, the tube going down to the catch-part was clogged, and so nothing new was flowing into the tray, and the liquid there congealed and molded over. I used a syringe to get out the liquid and scooped out the solids by hand (with rubber gloves!). Make sure your drain tube isn't blocked.
Posted on Nov 11, 2009
    Problem Solver:
  • 19 Answers
Hi there, you ay not want to detach it if its full and stinking!!
You could try using an ink syringe to remove a little at a time, alternatively a wet and dry hoover to remove it, then spray with something nice that is antibacterial.
Hope this helps, Chris
Posted on Nov 09, 2008
Refrigerator leaks
If it a frost free fridge it should self defrost every 6 to 8 hours all by its self. If you see ice or frost buildup in side the freezer usually back wall harder to notice if the cooling fins are just under the freezer floor but above the fridge ceiling or better picture it as the fridges taint. Sounds like the fridge is having defrost problems and if it every once in awhile does go into defrost or you do it, all that water flows down a hose and out the back around the compressor. Heat from the compressor or other gadgets evaporate the water. If it only defrost a few times a year it is going to overflow the catch basin. Easy to check some times catch basin or drain hose move check back bottom or remove front cover look if bottom catch basin. Main fault is defrost timer stuck in run, location all over in or out, defrost element around cooling fins,defrost thermostat on cooling fins,wiring to / from / joining the last two.
Mar 17, 2017 | KitchenAid KBRP20ERSS Stainless Steel
My fridge did not reset itself after a power outage over Christmas so I came home to a fridge of spoiled meat. I have cleaned everything but I am wondering if there is a drip pan or something that I need...
The evaporator tray is inside the bottom "kickplate". It is formed of flimsy plastic and must be lifted out carefully to avoid dumping contents. Dump it in the sink for subsequent scrubbing clean. Also, check the drainage tube in the bottom rear of the freezer compartment for clogging. It will have to be reamed (with a chopstick) and flushed to remove residue. Be sure to have the plastic tray back in place to catch drainage from the flushing operation and repeat the tray cleaning operation.
One final thing: Put an open box of bicarbonate of soda inside the refrigerator section to absorb residual odor. Good luck!
Dec 16, 2017 | LG (LRBC22522ST) Stainless Steel
Hi, i ve got the refrigirator model # MBB1952hew, and for about 2 weeks to a mounth now it has a really bad stinking odor, my husband says it might be from the electrical oils inside. but i ve never...
Hi Franny. Welcome to FixYa. I am Kelly
Get yourself 2 boxes of Arm and Hammer Baking Soda... cut off the tops and place them in your refrigerator. In 6 weeks change them out.
Now.... there is reason that it can smell and that is that the catch pan under the unit if full of some nasty goo. Unplug the unit Remove the fiberboard rear cover and use a shop vac to clean out the catch pan. While in in the area clean the condenser coils and fan. You can have a deceased rodent under your refrigerator.
Two other things that I use on an empty and dry refrigerator is Mr. Muscle Mold and Mildew Remover (use gloves) first by spraying it on letting it soak for a few minute then wiping it off AFTER scrubbing with an OLD / well worn Scotch-Brite pad. Then wipe off with a damp cloth.... air dry... spray and wipe with Endust (Major trade secrets there) That is how we recondition used appliances.
All of the above should get rid of the odors.
Thanks for choosing FixYa.
Kelly
Oct 01, 2010 | Maytag Refrigerators
Defrosting water flows backward inside the fridge.
Defrost water should not be visible inside the refrigerator. This water should drain from the evaporator coil to a catch basin in the rear of the unit (behind the inside liner of the refrigerator). The water then should drain into a plastic tube that carries it to a pan underneath the refrigerator. Heat from the coils and compressor then evaporates the water.
Something in this drain system is blocked.
Oct 18, 2009 | Refrigerators
Water is gathering in the bottom of my Siemens KG32U123GB fridge
Water created during the refrigerator defrost cycle drains into a catch basin (usually located behind the back interior panel of the refrigerator). This catch basin normally has a tube attached to it that carries this water to a pan located underneath the refrigerator. When the water reaches this pan, it is evaporated by heat from the compressor and refrigerant coils.
There is likely a blockage in this drainage system in your refrigerator. Looking at the back, you likely will see a tube exiting the back of the unit. If you can easily do it, pull off this tube and blow into it. If the tube is open, the blockage is likely in the catch basin. This is not good. To get this opened up, you will have to remove the back panel of the refrigerator.
Water is collecting at the bottom. Where is it
Refrigerators have a defrost water drain that carries water produced during the defrost cycle to the bottom of the refrigerator where it flows into a catch pan. The water is then evaporated by heat from the compressor and refrigerant coils.
Something is likely blocked in your drain system. There is usually a catch basin in the rear of the refrigerator behind the inside lining. From that catch basin, water flows into tubes which usually run down the back of the refrigerator. The drain in the catch basin may be stopped up, or the tube itself could be blocked.
Oct 15, 2009 | Refrigerators
Hot point refrigerator
Water can form in a fridge in the form of condensation.
There is a catch basin in the bottom of most refrigerators to catch this condensation and it may be overflowing.
Check that the door is closing all the way and the gasket that seals around the door isn't messed up some how.
If the 'fridge has an automatic ice maker, turn the water off to it and see if the leak stops.
Please give rateing after reading this solutions
Jul 04, 2009 | Refrigerators
Ice maker ice smells
Dump out the ice, let the icemaker refill the ice container, dump all that out as well and then it should be cleaned of whatever was in the line..
You may want to roll the fridge out and visually check the supply lines on the back of the fridge for contamination as well.
Jul 02, 2009 | Freezers
ODOR COMING FROM OUTSIDE REFRIGERATOR
Most refrigerators have a catch basin under the cabinet that is accessible after removal of the trim at the bottom.  This trim grill can have a half-dozen different fasteners on it although most have plastic extensions that are inserted into matching holes in the sheet metal that forms the base of the unit.
Try (gently) lifting the bottom lip of the grill while pulling it outward; if this frees the bottom edge, then angle the grill outward at the bottom and pulling it downward to free the upper edge. On some units there may also be a knob-like section that when turned releases the grill.
You didn't mention brand and model but with these, you should be able to find a downloadable manual on line that would detail how to remove the grill.
Once the grill is out of the way, most catch basins simply are lifted up and pulled out for cleaning and emptying.
To fully rid the fridge of odors, it may be necessary to pour hot (not boiling) water down any drains you see in each compartment several times to flush them.  Obviously, the catch basin should be in place when doing this and they can be quite shallow.
Good luck-
Dec 11, 2008 | Whirlpool GS6NBEXR Side by Side...
Drip tray full of water, don't know how to get it out to dump
How to remove drain pan on a kitchenAid side by side with water filter .
Nov 11, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
388 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
