Question about GE 7-5290 Clock Radio
Mounting template for kcd3180 clock radio
I need mounting instructions and/or template for mounting Audiovox KCD3180 under cabinet clock radio
MicrowaveSvc
  • 9098 Answers
SOURCE: wall template mount for ge profile microwave
You can may be able to order that by looking up parts by your full model number here.
Posted on Jan 11, 2010
SOURCE: I NEED A 24 IN. WIDE COUNTERTOP MICROWAVE TO BE
Sharp has a model 1214 that could work, but it is a little over 15" deep and will therefore not recess entirely into a 12" deep upper cabinet. I believe the install kit comes with it?
Posted on Jan 20, 2010
mcdevito75
  • 1970 Answers
SOURCE: what size bolts do i need in order to mount it
mcdevito75 here, Best Bet bring the mounting bracket and bolts recieved with the unit to your local hardware store. they will give you the correct bolts need to mount undera cabinet.
Posted on Jun 28, 2010
farmerbear
  • 490 Answers
SOURCE: We need an under the
Howdy. Here are the complete installation instructions in PDF:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40529.PDF
I read through the whole thing, and found it to be really straightforward, go GE:)
Regards,
Farmerbear at FixYa.com
Posted on Sep 13, 2010
SOURCE: GE JVM1650CH01 Microwave Template
I have this microwave and it shuts down constantly. I'll never own another GE.
Posted on Nov 09, 2012
Can you provide under cabinet mounting instructions for GE Microwave part WX4-A19?
To mount it under a cabinet, you have to have the under cabinet install kit; you'll find that here: Under Cabinet Mounting Kit WX4 A019 GE Appliances the kit does include instructions. You can't mount it without the kit.
Dec 12, 2015 | GE Microwave Ovens
Tip
How to upgrade the under cabinet lighting in your kitchen.
Hello. Here is a great weekend project that anyone can succeed with. Under cabinet lighting is such an enhancement to the function and cheerfulness of your kitchen. My most recent experience with this was very successful. The kitchen really needed the extra light and, the home owner let me choose the fixtures. I selected Utilitech line Voltage Xenon Lights from Lowes. These units come in three lengths, 12", 18" and 24". They can operate alone or in groups, they use 110 volts and no transformers, and they have a high/lo/off dimmer switch built in. Finally, they can be installed using the enclosed plug-in cords, or direct wired, and you can link up to 600 watts. A twelve inch bar is 40 watts.
All of that said, all you need to proceed is about 45 minutes per cabinet, and the following tools: electric drill and a set of wood flat drill bits, flat head screwdriver, philips screwdriver, wire cutters, wire strippers, pliers, safety glasses and a small mirror. The mirror will assist you in tightening the screws as you install the fixtures under the cabinets. Turn off the power at the breaker for the circuit you are working on [unless of course you are going to use the plug in cords included in the box instead of direct wiring].
VERY USEFUL TIP: probably the most difficult part of this task could be mounting each of the light bars uniformly under the cabinets. Recognizing this, I made a template for each of the three lengths of fixture so that I knew exactly where to predrill and start the two mounting screws required per fixture. These templates were made from still cardboard, cut with a razor blade knife, although you could have used 1/4 inch plywood just as well.
on Dec 07, 2009 | Electrical Supplies
I need a under cabinet mount
The VE1020 didn't come with a mount. It came with round plastic spacers (16) that were 1/4", 1/2", and 3/4" thick. You could stack these on the mounting screws to get the clearance you needed for under the cabinet mounting. You will note that there are 4 through holes for the mounting screws, one in each corner of the chassis. Sheet rock screws of different lengths will work. You can easily just cut four small blocks of wood or use 3/4" - 1" wood dowel cut to the length you need. Drill a through hole in the dowel. Paint them to match if they will be exposed.
Mar 26, 2014 | Audiovox VE1020 10.2 in. TV/DVD Combo
Over The rang microwave installation
I would say finish the wall, because the microwave needs the space for cooling.
Dec 17, 2017 | Samsung Microwave Ovens
Where can I get an instruction manual for Audiovox dual alarm clock radio for iPod CR8030iES?
search it in the internet google or yahoo... just type instruction manual for Audiovox dual alarm clock radio for iPod CR8030iES?...
Apr 25, 2011 | Audio Players & Recorders
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
Oct 23, 2009 | Jenn-Air JMC9158AAS Convection/Microwave...
No instructions for Jensen dual alarm clock radio with dock
Downloads for several Jensen clock radios available.
What model ?
Your model could be listed on the next page:
http://www.spectraintl.com/downloads.html
spec sheet
manual
Main link for support on Jensen products:
http://www2.audiovox.com/corporate/corp_jensen.do
Oct 19, 2009 | Jensen Audio Players & Recorders
Sony radio/cd/clock under the cabinet. Lost
On the right side there is a push button switch labeled "Clock". It is springloaded so you have to push it in and hold it for a couple of seconds until the unit beeps and the hour position starts to blink. The volumn up and down buttons will control the changing of the numbers up and down and PM/AM. Pushing the clock button again will change the clock to the minutes position and you cann adjust the numbers up or down just like the hours. Push it one more time will lock-in the new time. Your done.
Jul 20, 2009 | Sony UNDER-CABINET LCD-TV DVD/CD CLOCK...
You can download GE owner's manuals and installation instructions here.
Aug 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE 7-5290 Clock Radio Logo
407 people viewed this question
Top GE Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Jim Goldsmith
Jim Goldsmith
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
