Question about HP Computers & Internet
Putting the cable in the right spot
I recieved a new power supply for my hp 700 .i remove all the cable wire but don't remember were they go looking for a digram to see were they go.i know were the 20 pin connector went.
  • HOPPA Nov 10, 2008
    it's my power supply cable. and none of your picture open up.please try again.
    thanks hoppa
    Problem Solver:
Are you trying to find out for your power supply cables or your data/motherboard cables? There are a lot of different kinds of connectors, so make sure you have the right one plugged in the right way. Here are pictures of both:
Your computer may use both the older and newer style plugs and cables.
IF YOU HAVE THIS KIND OF CONNECTOR(OLDER) FOR YOUR HARD DRIVE, IT IS IMPORTANT TO REMEMBER THAT THE HARD DRIVE SHOULD BE PLUGGED IN TO YOUR PRIMARY IDE(PATA) PLUG ON THE MOTHERBOARD (IT WILL BE BLUE, RED OR A COLOR DIFFERENT FROM THE OTHERS). ALSO, SOMETIMES THEY HAVE A NOTCH, SO MAKE SURE THEY ARE IN THE RIGHT DIRECTION. THE PATA (IDE)HARD DRIVE CONNECTOR IS THE GREEN ONE. HARD DRIVES AND DISK DRIVES ARE 40 PIN AND FLOPPY DRIVES ARE 34 PIN(THE BLACK ONE).
putting the cable in the right spot - pata.jpg HERE'S WHAT THE CABLE LOOKS LIKE:
ide_cable2.jpg HERE'S A PICTURE OF HOW TO PLUG TWO PATA DEVICES IN AT ONCE. IF YOU HAVE ONLY ONE DEVICE LIKE THIS, JUST PLUG THE ONE END INTO THE MOTHERBOARD AND THE OTHER END INTO THE DRIVE, LEAVING THE MIDDLE ONE UNPLUGGED.putting the cable in the right spot - idecab.gif idecab.gif
A PATA DEVICE (AND SOME SATA DEVICES) USE A POWER CABLE WITH FOUR PINS Aputting the cable in the right spot - 800px-molex_female_connector.jpgimg src="http://i.fixya.net/uploads/images/800px-molex_female_connector.jpg" alt="800px-molex_female_connector.jpg" class="h_mi" />
HERE'S WHAT THE NEWER SATA PLUGS AND CABLES LOOK LIKE. THE CABLE ON THE RIGHT IS FOR POWER AND THE ONE ON Tputting the cable in the right spot - 06-sata_drive_conns.jpgIS CAN APPLY TO HARD DRIVES OR DISK DRIVES)
I hope I have helped and haven't confused you!
Posted on Nov 10, 2008
Replace power jack
Power supply failures in a HP computer can cause your computer to fail to turn on, to operate erratically or cause certain system components not function.
However, the power supply is one of the easiest parts of a computer to replace.
You don't need any special skills to do this.
If you're nervous about opening up your computer case and potentially damaging a computer component, don't be.
All you are really doing is plugging in power supply cables after securing the power supply.
The process should take 10 minutes maximum.
Shut down your HP computer.
Disconnect the power cable from the power supply on the back of your computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Unscrew the side panel from the back of the case and slide it off.
Newer HP computers may have a case door you can open for access or have access buttons to press.
Look at the back of your HP computer case for a set of four screws near the top of the case. Remove these screws and set them aside.
Carefully slide your power supply out of the mounting brackets and set it on a clean working surface.
Do not disconnect any of the power connectors yet.
Slide your replacement HP power supply into the case and use the mounting screws to attach it to the chassis.
Use your old HP power supply as a guide to connect your new power supply to all the computer components.
Switch the power cables from each device from the old supply to the new supply so you don't miss connecting any cables.
Check that all the components have power cables inserted and the old HP power supply is completely disconnected from the system.
Close the HP computer case and plug the power cable into the new HP power supply.
http://www.fonerbooks.com/r_power.htm
Apr 15, 2014 | HP Hewlett Packard Pavilion Slimline...
Tip
How to Repair HP Printer
HP (Hewlett-Packard) is well known for manufacturing electronic gadgetswhich are reliable and cost effective. In terms of customersatisfaction it is creating new mile stone. hp has introduced excellentprinter models in all ranges to meet the demands of both home andbusiness users. But due to some common issue, you may undergo afrustrating experience.
But don’t get down with your temper. There are leading solutionproviders in the market who can do the HP printer repair with greatsatisfaction. Even with simple knowledge you can also perform littlebit of HP printer repair work. Follow this article to resolve some ofyour printer issues:
1. If there is some paper jam issue, make a test printing. Observe thesound of your printer. Notice, how long the paper proceeds. If there ismultiple trays in your printer, try with different tray there might beissue with your paper tray. Its roller may have corrupted. You mayobserve the surface of the roller with your hand. You can replace theroller if required.
2. Follow the manuals to fix the new roller, slide it onto the prongand push it all the way in. You would hear the click sound. Hence, yourHP printer repair job is over. You can print a page for trail.
3. Issue pertaining to cartridges can be addressed in an easy manner.Open the left-hand door and look for the cartridge. Remember, don’tperform it when your printer’s fuser is hot, and allow it to cool.Firmly remove the fuser by lifting the locked hinges. Observe theroller of the fuser, if they are seized it means they need to bereplaced. Slide the new fuser cartridge and flip the levers to thelocked position. Power on the printer and make a trial. Most probably,this could solve your purpose and HP printer repair has been successful.
4. Some times you may not be getting any power on your hp printer evenwith proper power supply. In the situation you can do HP printer repair work by a smart judgment with the power cable used. Remember, laserprinters use a standard power cord, deskjet and photo printerstypically use a proprietary power supply. Again, observe the powerbrick, it should be warm but not hot. If it is getting overheated thenreplace the cable.
on Jan 20, 2010 | Office Equipment & Supplies
How to install power supply
get replacement first
turn off tower
remove all wires and connections
find case screws on back remove and put in a careful place
ground your hands with a strap to chassis
find power supply and trace power cables to board (2 or 3)
remove power cables
remove screws from power supply freeing from chassis
replace with new supply
plug in cables in same place as old one
close chassis
hook up wires to computer
count down from 10(just kidding)
maybe you get lucky
Jun 01, 2012 | HP Pavilion 735n Notebook
How do I change my starter?
the starter is held on by 2 or 3 bolts
1. disconnect the positive cable from the battery
2. press on the brake for 10 sec. to drain all the power out of the vehicles main computer
3. locate the starter and disconnect the positive wire from the starter motor
4. disconnect the ground wire from the starter motor
5. remove the 2 or 3 bolts that hold the starter in ( remember the starter only goes in one way )
6. put in new starter
7. put in the bolts torque the bolts to 23 ft. pounds
8. replace the power to power bolt tighten up tight
9. replace the ground wire to the proper spot
10. return the positive battery wire to the proper spot
11. start the vehicle
Good Luck!
Sep 13, 2011 | 1997 Jeep Grand Cherokee
How do you remove a starter from a 1999 dodge intrepid. 2.7 liter engine?
Good Luck!
Sep 13, 2011 | 1999 Dodge Intrepid
I have a HP Pavilion a450n and would like to know how to change hard drive. I looked at and think I know how but I am worried about breaking the green plastic. Anyone help me?
turn of pc, Remove from hdd cabeles, there is two, change you hdd and out cables in their place, you can not put power cable to another palce, there is all have their place, for example you can not put hdd power cable to hdd Ide otr Sata port.
Jun 13, 2011 | HP Pavilion a450n PC Desktop
I sent you problem about '91 olds without ignition or pwr windows,locks or trunk. You suggested i try checking fusable links on starter but they're all ok except for one purple wire coming from starter...
You should have recieved a reply from me on your other post. If not,
The purple wire is the power supply to engage the starter solenoid when you turn the key to the crank position. It should only have power when you are trying to start so thats nothing to worry about right now. Follow the positive battery cable from the battery. There is another fusible link that supplies power to the ignition switch. For the life of me I can't remember specifically where is it but I do know it is under the hood somewhere along one of the positive cables.
Dec 10, 2010 | Oldsmobile Cutlass Ciera Cars & Trucks
How do I remove the CD drive and install a new one? lynnwood@kctc.net
switch off the pc and unplug from AC. remove screws at the back of ur case( located vertically on the slide case). remove both right and left covers and look for internal cables i means power, ide or sata cable. remove them and remove the screws of ur drive and pull it in front and in the same spot push ur new drive in the same place. replace the screws, reconnect cables, power,ide or sata. then place side covers and make sure to have tighten all power and internal cables to their slots well.
Aug 03, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
Install hard drive in hp a1310n
You need to do a number of things:
1) You need to carefully remove the door and the whole front face of the desktop (the front face opens like a door it swings open from left to right)
2) Once you have the front pannel open take a philips screwdriver and unscrew the memory card readers that is show in front of the deskop (there is one screw holding this card reader in place probably on the upper right hand corner.
3) Carefully remove the card reader by jiggiling it lightly till the unit comes off.
4) After you remove the card reader, you will immediatly see the hard drive directly behind the reader that you just removed.
5) Now look inside the desktop (because you removed the right hand side door: the big one that alows you to see inside the pc) and remove all cables from this hard drive before you read #6 below
6) Inside the desktop, Locate the hard drive, put your hand on the back of it and lift on the green plastic part along side the hard drive where you can see the harddrive screw which is on a metal track stopped by a green plastic stopper.
7) Lift the green plastic stopper and push the back of the hard drive to the front of the desktop.
8) Unscrew all screws from old hard drive and rescrew them on the new one in the exact same spots at the old hard drive.
9)Once you finish screwing on the screws, slide the new hard drive back from where the old one was
10) reconnect all data cables and power supply cable.
11) follow steps 7 thru 1 to put unit back together again. Go thru steps 7 thru one backwards
I hope this helps
Mar 18, 2010 | HP Pavilion a1310n PC Desktop
HP 5470c - No power
I've done it, using an adjustable power supply all i needed was 12VDC - 2Amp, the power connector going to the scanner is a 4 pin mini-DIN male, so i've ripped of the cable from the original bad power module, cable has inside 2 wires one black one white and a shielding. Black and schielding are connected together and are going to the minus, the white one is going to +12V
guess what? .... my scanner is working again
Nov 25, 2007 | HP Scanjet 5470c Flatbed Scanner
Computers & Internet Logo
63 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
