Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer won't final spin
Model #ftfb4000fs1
everything works fine except won't final spin. ran diagnostic test and had a code e43. I installed new main control board ($153.00) still have the same problem.The code is still there too. I tried unplugging it overnight to reset computer and still have the same problem
  • brian477 Nov 11, 2008
    Same problem here, door lock mech seems fine, but no final spin. Any suggestions out there?
  •  MERTZMOTO
    MERTZMOTO Nov 11, 2008
    Started having this problem last night and plan to tear into it tonight, did anyone come up with a fix besides the control board since that doesn't seem like the issue?
THERE ARE A COUPLE OF CONDITIONS THAT WILL PREVENT THIS UNIT FROM SPINNING :NOT COMPLETELY DRAIN AND FAULTY DOOR LOCK AS SY.
FIRST REMOVE ELBOW ADAPTER HOSE FROM TUB TO PUMP AND MAKE SURE IS COMPLETELY CLEAN ,HOSE STRAINER THEN CHECK IMPELLER @ DRAIN PUMP NOT TO BE BROOKED , DEFORMED .DIRTY OR LOOSE IF IS LIKE THIS REPLACE PUMP IF NOT PUT EVERYTHING BACK TOGETHER ,MAKING SURE THE STRAINER IS ALL WAY DOWN (IF IT HAS ONE) IF NOT IT WILL GET LOOSE AND DAMAGE YOUR OUTHER TUB ,THEN THIS IS IT .
THEN CHECK PRESSURE SW HOSE FOR LEAKS AND BLOW SLOWLY AND CAREFULLY TO CHECK PRESSURE SW .IF CHECKS OK THEN REPLACE DOOR SW ASSY AND RUN ONE IM VERY SURE THIS WILL TAKE CARE OF YOUR SITUATION ;NOW GET ON YOUR KNEES , GET DIRTY AND HAVE A GREAT DAY!
MAYITOJHONES
Posted on Dec 04, 2008
    Genius:
  • 1,028 Answers
List of codes is behind bottom panel on tech sheet attached to right side ..f43 may be door lock ..if door lock is bad washer may do a slow spin but never go to max
Posted on Nov 09, 2008
No definite solution but possible assistance.
Which control board was replaced?
There is a motor control board below the tub and control board behind the console.
Posted on Nov 18, 2008
    Problem Solver:
  • 10 Answers
My problem turned out to be a bad connection on the motor control board. Reseating the cable connector fixed the problems that I was having.
47 is the door lock code, 43 is control panel, but I have the same issue, replaced the control board and no luck.
Posted on Nov 11, 2008
Hi, I have a frigidaire front load washer, model FTF2140ESO, that is making a high pitched screeching noise when it enters into the final spin cycle. The noise ramps up in volume as the drum spins faster....
Some times screws can work their way out near the drum and rub against the drum causing the squeak. You might have to take off the back of the washer and see if there is anything loose contacting the drum.
Oct 16, 2013 | Washing Machines
Front loading model #FTFB4000FS1 is not draining....have to run the drain/spin a second time to get the water out....where i s the filter?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
Model #ftfb4000fs1 frigidaire front load washer will not go into final spin --- drains but will not spin dry
Just had this problem last week. The problem was the door switch, which made no sense to me since the drum still turned on the other cycles. But the repair shop replaced the ($76!) switch and the machine now works fine.
Oct 21, 2010 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Dec 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer spins while washing, it will also drain with no issue but will not do the final spin? help!
Any error codes? Try putting it in diagnostic mode. You can test different cycles and retrieve error codes. Instructions should be taped in an envelope to the inside of machine. You may have to remove the bottom front cover to find them.
Most likely cause - Faulty door switch.
Oct 08, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front Load Frigidaire Won't Spin Out
I had the same problem listed above on my LTF2140ES3...the machine did everything but do a final spin. In diagnostics I could do the final spin and the machine kicked out an E43 which is the control board error.
Following the advice here I changed the door latch first and the problem went away and the unit runs as it should.
You'll get "experts" who say that the unit would not spin at all if the door latch was bad. I can tell you first hand that they are wrong. Again the unit did all the normal tumbling but didn't do the high speed final spin. Again, replacing the door latch fixed the problem. The door latch is part number 131763245 (AP3886713)
Jun 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load Fridgidaire ftfb4000fs1 won't spin
This is a fault that resides within the motor control board. you will need to replace this failed module asap if possible. it has failed.
Jun 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ftfb4000fs1 front load washer will not spin
hello **** theres a circuit board on the back or on the side called a module this controls the spin cycle there could be dry joints on the board or component may have fail good luck
shaun
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer FWFB9100ES1
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
• On non-digital display models, turn the Program Knob to start position, Drain/Spin.
• On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that
can be rotated 360°, turn the Program Knob to start position, Drain/Spin.
• Press Pause Cancel to turn off LEDs.
• Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then
release buttons.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
1,941 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
