Question about Dewalt DC011 AM/FM Radio
Radio charges batteries but thats about it.
When I goto power on the radio the lcd give just a flicker of light then nothing. It seems to charge batteries just fine but tunes would be nice at the job. I checked the fuse inside and it is fine. Could a bad transformer cause this problem. I had it open and plugged it into 110v and tested the transformer It was giving out about 63.2 volts. I am not sure if this is the right output. Any help would be much appreciated.
    Champion:
  • 313 Answers
It say's beside the lcd the info of what type of flicker gives you.
it will till you if the battery you chager are good
Posted on May 29, 2008
    Problem Solver:
  • 10 Answers
Check the AA Batteries.
Posted on Dec 21, 2007
I have a 2006 stratus won't stay charged n dash lights flicker n radio cracks
Have the battery tested & load tested too. Naturally ck the charging syatem & ck for electrical shorts.
Jun 25, 2017 | Cars & Trucks
Bought a new alternator due my old one FAILED the test. But, I still have the problem with my head lights flickering & stereo going off then on when I accelerate to go.
Diagnosing Common Automotive Charging System Problems
www.onallcylinders.com/.../diagnosing-some-common-charging-system-...
Sep 18, 2013 - Flickering gauges. ... Problem: The charge indicator light flickers while driving. .... My alternator has been replaced for the third time in 5 months. ... I bought a new regulator but it is still doing the same thing... .... my headlights wont turn on, car runs fine when jumped, battery last for maybe 3 hours, any ideas ...
All lights Flickering/Pulsating only when motor is running ...
www.cadillacforums.com/forums/cadillac-forum/t-221843.html
Feb 11, 2011 - So i have noticed for a while now that all my interior lighting (radio, tach, even ... Installed the battery and have not had issues starting since then. ... So now ipurchased a new alternator "just in case" figuring i would eliminate the .... Interior lights and headlights still seem to pulse/flicker while idling the most, ...
Lights Flickered. Replaced Alternator. Now more flicker? - Camaro ...
www.camarozone.com/.../lights-flickered-replaced-alternator-now-more-...
Apr 22, 2013 - 20 posts - ‎4 authors
Jan 19, 2016 | Cars & Trucks
I have a 2002 KIA Spectra that will not start. I turn the key and nothing happens. No lights, dash lights, nothing!!! I had the battery checked and charged at AutoZone and put it back in. Still nothing....
you always have to reset when you take the battery out or it goes stone dead. loosing power sounds like a battery going dead due to no charging. charge it up and drive it bck to auto zone for an alternator check.
Jan 22, 2015 | Kia Cars & Trucks
Cobra cxt195 won't charge
There is nothing wrong with your battery or your radio. you bought it a walmart at the lowest price available. this means you get what you pay for i.e. no frills the indicator flashing means it is connected to a power source and is charging / Maintaining the battery. it will only come on again when the battery is below 1/8th of the battery life and flash to let you know it needs to be charged again. there is no battery level indicator. these will work just fine but dont expect the 1-16 mile range they advertize unless you have full charge alkaline batteries and a direct line of sight to the one you are talking to.
Dec 12, 2013 | Radio Communications
Works off battery or A/C, but will not charge.
The charger unit is fried It is expensive to fix and not worth it
Jul 26, 2012 | Dewalt DC011 AM/FM Radio
Battery light comes on, then radio cuts in and out and dash lights flicker. Also the driver window switch causes the radio to cut out when used.
I can help you with the first problem. The battery light comes on when the charging voltage drops. With the car running you should see a charging voltage of at least 13.5 volts and preferably 14 volts. You can check this with a volt meter at the battery. If you see 12 volts than there is a problem with the charging system and most likely the alternator has gone bad. You should check for power on the terminal that the large wire goes to on the back of the alternator. If there is power than a new alternator will more than likely take care of the problem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jul 22, 2011 | 1999 Plymouth Grand Voyager
The A/T oil temp gauge, the emergency brake light, the radio flickered, and the panel lights were dim or flickering... as I was climbing a hill the car sputtered with gas in it. The thermostat did not...
seems like you need an alternator try charging your battery star the engine and take off negative cable if engine dies it's your alternator. did you have an alternator light on in the dash
May 24, 2017 | 1990 Toyota Corolla
Batteries not charging
Michael
Are the batteries the original power pack? this charger are disigned for work just for this batery packs only.
Check if the conctas on the battery lead for dust or corrotion.
Oct 08, 2007 | Motorola Talkabout T5700 AA (22 Channels)...
Flickering LED flashlight
It sounds as if the connections in the back of the radio may not be continually connected to the contacts on the charging base. You might want to make sure that the radio is properly loaded in the cradle of the charging stand. The reason why the lights 'flicker' is because if your power goes out, the light on the radio will come on when it detects no power to the charging base. This is a feature to many new emergency radio gadgets. Imagine a storm rolling through your area and the power goes out in the middle of the night. Your Vector radio's LED lights come on so that you aren't searching for the radio in the dark.
Jun 23, 2007 | Vector VEC438 AM/FM/Weather Radio
Dewalt DC011 AM/FM Radio Logo
231 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Daniel
Daniel
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
