Question about Maxtor Hard Drive
Windows does not boot
I have windows xp home edition and  windows doesn't start. I tried recovery from hard drive but  i get a black screen with ( _ ) intermitent and i can not go to anywhere. I tried too pressing F8, F10, and F12 and one more time i got the black screen or windows blue screen stop: 0x0000008E, 0xc0000005, 0x00000080413051, 0xF6ECD778, 0x00000000, or windows system 32 error 257. A friend mine gave windows xp professional cd and at to install i was at 2% of installation but were more than one hour and half and i thinking installation was too delay i turned off the computer.After this i got the same black screen or windows blue screen describe above. Is there any one can help me?
  • 63 Answers
This sounds like a reformating job required here. You need your Windows CDROM and it is important that it is your own and not regitered to your friend outwise you aere going to have the same problem later when you are asked to validate Windows.
Boot your PC, Open the DVD/CD player draw and put the Windows disk in, switch off your PC. Reboot your PC and press Del to go into setup, in setup press the down arrow once and press enter, on this page halfway down or there about you will see First Boot -------Second Boot---Its the first boot one you want , set it to CDROM by pressing + touch nothing else, now press F10 then press enter. Your PC should now be Booting to CD.
It will run on to a point where you have to choose a partion to format Choose C or 1.
After that it wont need you attention for quite a while, it will automatically start installing Windows files upto the point where it needs the Product Key, after that you will need to configure the keyboard settings then the rest the PC does. Good luck.
Posted on Nov 21, 2008
2 Suggested Answers
  • 52 Answers
SOURCE: Windows xp home does not boot
Replace the HDD.
You don't want your precious data on that drive.
Posted on Jan 01, 2009
Only the cursor show on the screen
try enter the bios setup, check if the hard drive is detected or not. go to the boot order. set the hard drive as a first boot order. save the change by pressing f10. if it still can't log on to the window, run the recovery console... it should fix the problem
Jun 13, 2012 | Compaq Presario 700 470024-192 Notebook
I cannot get my computer to boot. It just goes to a black screen after the acer logo and then the Microsoft loading screen comes up and then goes back to the black screen and that's it. I tried system...
This is a hard drive issue, remove hardware and reseat it back into place, sometimes this will work and run fine. But it is more than likely your hard drive will need to be replaced.
Mar 06, 2012 | Acer Computers & Internet
BOOTMGR is missing
go to a torrent and upload and save the Windows XP program to your hard drive. Try to install it from your hard drive but use your own Serial Number
Jan 31, 2010 | Microsoft Windows XP Home Edition
Windows XP Home Not Booting
For that you need to recover error on hard drive then you can see repair option.
For that insert windows disk or recovery disk in cd/dvd rom.
Then boot your computer with it set first boot device as cd/dvd rom in bios.
Then follow the procedure select "R" for recovery console.
Then type in prompt "chkdsk /r" then press "y"
then it fix error on hard drive.
Then restart computer then it search the previous windows then you can see "r" for repair previous windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 07, 2009 | Microsoft Windows XP Home Edition
Windows xp will not install
If you don't see the message on start up "Press any key to boot from cd" Then you need to change the boot order.
Start the PC and hit delete a number of times. This will take you into the bios screen. (Set up screen)
You will have a tab called "Boot Priority" or "Boot order". Make sure that CD/DVD drive has 1st priority. Save & exit & your done. Upon restart if you have a disc in the drive you will get the option to press any key to boot from CD/DVD. By default, most motherboards are set to boot from floppy & then Hard drive so in most cases you will need to enter setup & change the boot order.
Don't forget to rate me.
Oct 19, 2009 | Microsoft Windows XP Home Edition
Have a travel mate 2423wxci preinstalled windows xp home edition. Have formated the hard drive but can't find the recovery disk. How do I get one?
Did you format the whole drive?
If you didn't fully format the drive then the Recovery Partition could still be intact.
Start the laptop up and at the splash screen keep tapping F10 or ALT+F10 and if the Recovery Partition is intact the laptop will start the recovery process, if you get a message say BOOT EXECUTE/NO then the partition is not there.
You have 2 options now:
  1. Call Acer and get a set of recovery disc's, will cost approx between £20-60 for a set of discs.
  2. Buy a copy of XP home edition and then download all the drivers for your hardware.
Thanks
Sep 05, 2009 | Acer Computers & Internet
Win XP Home no longer works, won't boot from cd/or hd
You have a virus most likely. You will need to boot with an antivirus cd & let it scan & repair the virus damage. After this is done you should have control of your system again. Hope this helps.
Mar 30, 2009 | Microsoft Windows XP Home Edition
Replace the HDD.
Nov 08, 2008 | Maxtor Hard Drive
Windows xp home edition computer will not start
If the system cannot start on safe mode probably your operating system has gone bad, to check your hard disk you can go use your windows xp disk, to boot from it press f12 choose cd rom keep on tapping enter and dont mind the message that you need to press any key to boot from cd, and then when you are on the welcome to setup page press r for recovery console, once you are there try to type in chkdsk /p and after type in fixboot and press y, and restart your system, if that wont work then your hard drive is bad.
Oct 31, 2008 | Microsoft Windows XP Home Edition
RE: WINDOWS XP
Have you tried starting it with a XP recovery disk??
Jun 18, 2008 | Microsoft Windows XP Home Edition
Maxtor Hard Drive Logo
197 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
