Question about RCA F35731MB 35" TV
Flickering Picture? My RCA F35731MB 35" TV seems to have what I call a "flickering" problem. There are lines that flicker horizintally on the screen making the picture seem like it may shrink and close. When it flickers there is a noise that comes from the rear of the TV. The flickering is intermittent, sometimes it would be OK for a couple of weeks then one day start flickering. Sometimes the picture seems to stretch so you cannot see the names on a TV show at the bottom of the screen. This happens in conjunction with the flickering problem. I have tried unpluggin TV overnight, moved TV away from walls and played around with the vertical hold but to no avail. Does anyone have know what the cause of this may be? Thanks, Tony
    Sergeant:
  • 337 Answers
Your set might have a high voltage leak and that is the noise you hear when is showing the screen problem or even maybe an arking too ,either one is related to the high voltage and it can be dangerous,if you are familiar with tv service you can try to see where is arking and replace the part with an exact replacement but if the set has a leak you will not see it and is not safe to be close to it,if you are not too familiar be safe and call for assistance from a servicer.
Posted on Oct 27, 2006
  • Omar Urrutia
    Omar Urrutia Oct 27, 2006
    Your rating response is also important.
My tv keeps turning itself off what do i do
Posted on Mar 17, 2010
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Samsung tv has flickering lineswhile watching tv
? 3:43
Jun 4, 2012 - Uploaded by Tampatec How to Fix Samsung TV Flickering Blinks Flashing Flat Screen ... Rating is available when the video has been rented. ... sorry to bother you tampatec but i have a RCA tv it works great when it's.... My Toshiba Full HD led tv model 32PT200ZE is having issues of screen blinking/flashing and horizontal lines.
Sep 25, 2015 | Samsung Televison & Video
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Rca 42in full hd lcd picture flickers
If the picture on your TV flickers, there may be a simple fix. Here are some possible answers and suggested solutions:
1. Your set-top box may need a simple reboot. Unplug the power connection to the set-top box for about 30 seconds. Reconnect the power and turn the set-top box back on.
2. Check all of your cables for a loose connection by tightening each one with your fingers.Flickers can sometimes be caused by bends in rigid cables, too.
3. If your picture flickers to a black or blue screen, you could have a bad set-top box. Contact your cable or satellite service provider about installing a new one.
4. If you still have audio, the flickering could also mean that you have a failing backlight.
For additional troubleshooting information, check out the chart at TV flickering for more solutions. I hope this helps!
Sep 14, 2012 | RCA Televison & Video
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Apr 14, 2008 | RCA L46FHD37 46 in. LCD HDTV
Televison & Video Logo
1,668 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
