Question about Dell 922 All-In-One InkJet Printer
Printer not feeding paper properly or at all..
It's almost like one side of the paper feed is feeding the paper through and the other isn't. This creates a jam on one side. Sometimes it will work properly then pull the 'Paper Jam' routine when there isn't one. I hate to throw the printer out; it is less than 1 1/2 years old.
  • Anonymous Mar 12, 2014
    it seems like it is only feeding from one side and not the other
We find a drawing pin in ours - ten points for the "picking upside down and shaking method"!!
Posted on Aug 25, 2007
  • boys3mom Apr 11, 2011
    Worked great! and worked out some frustration at the same time!! I added in a lot of "whopping" along with the above suggestion. Didn't take long to see that a peanut M&M was the cause of the problem. I have an abandoned printer with same symptoms at home, can't wait to work it over. Finally, a solution in the high tech world that I can handle! Thanks!
I'm on site tech support for a client in Winston-Salem, NC - we found a pen in ours. Bless you all for the idea to check. I would've never looked had I not seen this site.
Posted on Jul 24, 2007
Mine had a crumpled up shred of paper in it. I had to unbend a paper clip to dig it out. After alot of digging, and shaking, and partially disassembling the printer, I got it out. Thanks for the tip
Posted on Jul 13, 2007
I had this problem too. But instead of chewed gum I found a little plastic toy inside. Kept the printer (deconnected) up-side-down and the problem was solved!
Posted on May 16, 2007
I had exactly this problem. The roller side of the paper fed through, the other side did not feed at all. After trying different sheets of paper and watching the printer jam 10 times, i finally peered inside and saw a pieced of dried up chewed gum inside. None of my 4 kids knew anything about it. Using a ruler I removed the gum and solved the problem.
Posted on Feb 23, 2007
SOURCE:
Paper will not feed
Hi, maybe there is still a little bit of jammed inside that you can\'t see. Try to see if there is and clean it. If you\'re sure there is no paper jam whatsoever, then there is a conflict with your feeding sensors or your cartridge isn\'t properly installed.
kind regards
Apr 17, 2013 | Lexmark X4650 InkJet Printer
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
When trying to print getting error Paper Jam in Manual Feeder. There is no Jam...we tap the side of the machine and it prints....any Ideas on what causes this to happen?
There is likely a loose connection going to the manual feed paper sensor.
The printer thinks there's paper in the manual feed, but of course since there isn't any paper there, when it tries to feed the paper in from the manual feed, the next paper sensor is not tripped, so it assumes there is a jam in the manual feed.
Start testing at the manual feed sensor, and work your way back to the board it connects to.
It may be the sensor itself just needs to be cleaned - these sensors are usually optical, and spraying canned air at it will often fix it up.
Also, make sure the lever that trips the sensor isn't sticking after using the manual feed.
Apr 11, 2011 | Samsung SCX4623F Laser All-in-One Printer
My printer will not feed the paper properly. It
There must be a jam on the left side then. Open and look inside for the paper issue
Jun 16, 2010 | Lexmark JetPrinter Z11 InkJet Color...
Paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper.
"paper won't feed properly- feeds at angle and jams. Printer indicates that it is out of paper."
I am having the same trouble, what was the solution?
Oct 15, 2009 | Canon PIXMA MX330 Multifunction InkJet...
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Jul 02, 2008 | Office Equipment & Supplies
Paper jam
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 28, 2008 | IBM Lexmark Z715 InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
1,217 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
