Question about Yamaha RX-V800 Receiver
Rx-v800 shuts off after few seconds
I got a Yamaha rx-v800 and had it for a couple of years and recently it would turn on and it would work fine untill you start turning it up a bit and it will just shut off. You can turn it back on but it will just shut off right away.I was wondering if there is a way to fix it.
  • 3 more comments
  • Anonymous Nov 01, 2007
    the above same dialouge but with displaying check speaker wires,even after after removed speaker wires.
  • ashok_123 Nov 02, 2007
    hi,my yamaha rxv800 switches off while tuning up the system with check speakers,even though speakers wires are removed.pl solve this.
  • marasli Feb 10, 2008
    I have the same problem,my yamaha rx-v800 already 3 years old and when swicth on it goes to shut in afew seconds.
    any solution for this? thanks.
  • eighty88 Mar 05, 2009
    I have an RX-V1600 Receiver that is doning the same thing, it turns on then a few seconds later it shuts off. It will start up 3 times then I have to un plug it and plug it back in and it will start and shut down another 3 times etc... I checked the ground and both fuses (15amp and the 25 amp fuse) they are all OK. HELP.....
  • Anonymous Mar 22, 2014
    My a Yamaha RX-V659 receiver shuts off when the volume increases or an action scene comes on. I have not had this problem previously. I am a little hard of hearing, so I tend to listen to my stereo with a little bit of volume. The audio does not have to be particularly loud for the receiver to shut off. If I turn it back on and turn down the volume a bit, it seems to stop it for a while, but if I turn the volume up it happens again. What can be the cause of the problem and how can it be fixed?
I had the same problem and I sent it in for service. They came back and said it was due to a cap that went bad.
Posted on Jan 19, 2009
Hi, You should try to see, on main board, the ground G2(TP00385), just to make sure if the screw is too tight. Its location on Schematic Diagram (Main) is E8. All the best, Rasgador
Posted on Sep 17, 2007
RX-V800 shuts off after 7 seconds turned it on, what should I do?
Can you post that diagram here? Or you can email it to me. I can't make any promises, But Im glad to help, I have done much board work in my time, and this one just sounds interesting. L8R
Sep 16, 2007 | Yamaha RX-V800 Receiver
Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Feb 13, 2010 | Yamaha RX-V800 Receiver
Yamaha RX V800 w/ iTunes Airport Express
thats cause your patch cable is mono get a stereo 3 ring connector.
Apr 01, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V 800
give me more details of trouble... let me give you advise if it can be done. 800 does not have industry standard parts mostly by yamaha only or made to order by yamaha. I have the same unit before, i have the manual too.
i use to work with yamaha service saudi arabia 6 years
Feb 24, 2008 | Yamaha RX-V800 Receiver
Yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
redrivera0314@yahoo.com
Feb 04, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V800 - No audio on left and right channels
I too am experiencing this problem.... and my receiver is only 5 months old. Its a RX-V661
Oct 30, 2007 | Yamaha RX-V2500 Receiver
Problem in yamaha rx v800
Hello!!! Are you electronic technician? You should see the transistors Q22A, Q22C, Q19C e Q19A and its drivers on Main Board. All the best, Rasgador
Aug 03, 2007 | Yamaha RX-V800 Receiver
Problem in Yamaha rx -v 8000
your system goes on auto protect mode. it can be repaired even without the shcematics if this is the only problem.
what particular module is he asking for?
Jul 29, 2007 | Yamaha RX-V800 Receiver
Yamaha RX-V800 Receiver Logo
519 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
