Question about Panasonic PT L711XU Multimedia Projector
Projector won't show picture
My projector will not show the picture when hooked up to a laptop or a DVD player. The lamp is not burnt out because it still shows the blue screen and the menu. We have tried the RGP cable cord and the S-video cord too. We have played around with seetings on the projector but still cannot seem to get it to work. Any suggestions?
My projector will not show the picture but i have sound
Posted on Feb 16, 2010
I have a acer projector ph110, it telling me to replace the globe. Change the globe but can't get into the menu screen to reset globe hours. Try pressing the menu botton but it stll have the warning...
Hi, I had the same problem all you have to do is connect something to the projector like a laptop or dvd player so it has a signal. Once the picture comes up of what you are projecting from the laptop or dvd player you can enter the menu and reset the lamp hours. Hope this works for you if not please let me know.
Mar 30, 2011 | Acer PH110 Multimedia Projector
Changed lamp and now turns on and only stays on for about 5 minutes and red lamp light stays on in an acer ph110 projector
Hi, what you need to do is reset the lamp hours to get the red light to go if it is a new lamp. To do that plug in a source such as a laptop or dvd player. When the display from the laptop or picture comes up go into the menu and reset the lamp hours I had the same problem. Hope this works if not let me know.
Nov 10, 2010 | Acer PH110 Multimedia Projector
I can't get a picture when I hook my projector up to my laptop.
HELLO,
If your LCD or DLP projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F7 once: The laptop screen only
* Press Fn / F7 twice: The projector port only
* Press Fn / F7 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
Hope this helpout....
Jun 17, 2010 | HP Digital Projector Vp6110 Multimedia...
What does a lamp bulb look like when it is no longer good or working? does it look burnt out? Mine looks like nothing it broken or burnt, but my projector isn't showing a picture on the screen. the fan...
look at the lamp head on. an obviously bad lamp will have cracks in the mirror, the stem can have frosty,veiny looking blisters or bubbles, the mirror can have lots of bubbles. And sometimes there are just no obvious signs.
Jun 14, 2010 | InFocus LS 110 Multimedia Projector
The projector is projecting an "out of range" message for a powerpoint presentation. I know it works b/c it switches to DVD just fine. Also, when I unplug the cable from teh comp to the projector the...
Whether you have a laptop or a desktop hooked up to this projector, you will need to adjust the resolution of your desktop to a level that the projector can handle. Without the Model number of the projector, I cannot tell what the resolution should be. I would hook it up and then lower the resolution level of the PC as see if it shows a picture. Does the projector show your desktop image on the screen? If not then changing the resolution will solve the problem.
I hope that I have provided the correct information that will assist you in the resolution of this issue.
If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 06, 2009 | Computers & Internet
Dual screen showing on screen
Turn off Progressive Scan in your DVD player. The LP500 can't handle PS.
Apr 03, 2009 | InFocus User guide, LP500 / 530 Projector...
Showing to of the same thing twice and colors
The projector has one or more "burnt" polarizers, more than likely.
They are replaceable, but expensive if you buy them from the manufacturer.
Look on Google for "burnt polarizer".
It's not the easiest job, but at least they're replaceable.
Jan 15, 2009 | Toshiba TLP-380, TLP-780, TLP-781UF...
Projector problem
If replacing the lamp did not fix the problem, I would suggest to check the cables that bring the video from a computer or any other device that you are connecting to the projector.
Also try to hook up a DVD player using the video output from the DVD to the video input on your projector.
Good Luck.
Feb 05, 2008 | Televison & Video
I want to know whats ronge with my projector
the lamp needs cooling when it gets to a certain temperature. Wait for it to cool and then turn it back on then hook up the dvd player. Got it?
Jan 26, 2008 | Sharp XR-10X Multimedia Projector
Panasonic PT L711XU Multimedia Projector Logo
396 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
