Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Sony kp-53hs30 i have a sony kp-53hs30 TV that I bought 5 years ago. The front screen lens or protector is cracked. Any idea how much they cost and if it is easy to replace or do I have to send it in for service?
  • Anonymous Mar 08, 2009
    i can't find a replacement either
I was checking for one similar.The name is "LNTICULAR"
In Texas you can find a provider
Price $280.00 plus $80.00 S&H more o less.
Let me know to send the address
co6bg@yahoo.com
Posted on Apr 09, 2009
How to clean behind the screen. there is cobwebs and dirt showing when the tv is on. making a bad picture thanks deb
The safe and easy way to do this is to first unplug the set and then remove the back cover.
Most likely you are seeing spider webs; with the back off I use a swiffer duster with a fairly long handle. Clean the three large black lens you will see with a lens cloth or a paper towel with glass cleaner sprayed on the towel.
With the duster get all the webs and do not apply force for any attached to the inside of the screen.
Common problem and I have seen it many times. It is a good idea to clean the lens on the three tubes once a year--any dust on them will make the picture look somewhat darker and dull.
SD TECH
May 14, 2010 | Sony KP-53HS30 53" Rear Projection...
I recently bought a Sony KP-53HS30 rear video TV
Hello Sarah!
There is no bulb to replace in your TV. Image is created by three CRT's and you don't want to replace them, just trust me on that one. It could cost you up to $1800 to do that.
All you can do is to clean lenses of those CRT's. You have to disconnect TV from the power outlet and remove rear cover. Using very soft brush and vacuum cleaner remove dust from Red, Green and Blue CRT lenses. Do not use solutions unless you got something special for optics. Solutions will leave film on the surfaces. That would improve brightness and contrast of image.
To adjust focus front grille have to be removed. Than central piece cover held by 5 screws. Behind it you can locate black plastic "box" size little smaller than cigarette pack. there are 6 adjustment "screws". Three of them are "screen". You don't touch those. Another three "focus" there is one for each color. Turn TV on. Hit "menu" button. And adjust focus for each color separately. If menu goes away hit it again.
This is the only improvements you can do.
Everything else will involve humongous amounts of cash.
Russ.
Apr 04, 2010 | Sony KP-53HS30 53" Rear Projection...
Connecting the laptop VGA output to my Sony-KP-53HS30
There are products such as VideoSecu PC to TV Presentation Converter. I haven't used them. I'm not sure you are going to get the resolution that you want. A DLP projector does a pretty good job. I know that is not what you are looking for.
Type "PC to TV Converter" in Google. They are about $40 to $60 bucks. Before you buy one, read the reviews.
Dec 27, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony kp-53hs30 rear projection TV
replace the two convergence ICs and a couple 3.5 amp pico fuses. You need STK 392-560 convergence ICs. You can get replacment ICs and pico fuses at the following link. with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Aug 15, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53 screen
Try to call this guys and see if they can help you.
Apr 14, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30
sent the info to your email address
Mar 31, 2008 | Sony KP-53HS30 53" Rear Projection...
Thank you
any time ...is my plessure to help
Mar 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Progressive scan
progressive scan? does your tv support 720p, or 1080p HD? (the p actually stands for progressive scan).
Another alternative to that is: http://www.playerschoicevideogames.com/pd_psp.cfm
A bit more expensive, but i think it works on any tv.
Jan 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Grey Screen with 480p signals (or higher)
I've had a KP 53HS10 for close to 8 years I think. 4 years ago the picture started blinking after long use, then more and more often. I had a repairman come and replace the tuner card (that's all I know about what he did). Now that I finally have HD from cable, I've found that 720 doesn't work and 1080i works, but the picture blinks on and off apparently struggling with some inner problems. Everything looks great, for a second and then it blinks. The red light blinks 5 times repeatedly while this is going on. I called SONY 5 times means get a repair man. I searching forms like this for help as well.
Nov 18, 2007 | Sony KP-53HS30 53" Rear Projection...
Distorted picture
dont touch those lenses that is not your problem the problem is your convergance ic are bad replace them and the fuses and this will fix your problem
Sep 15, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
134 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
