I have a homemaker hmw60501G, its only 14 months old. Just recently it won't spin anymore. It makes a loud sound but won't spin at all. I've looked underneath but all looks good. The belt seems to be tightened but nothing.
  • db2009 Apr 26, 2009
    I also have the same model with the same problem. I've had a look at the machine and I think that something is stuck between the inner and outer tubs, preventing it from spinning freely.
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
SOURCE: maytag spinning loud noise
bearings are bad need to replace
Posted on Mar 14, 2007
SolutionGuy
  • 331 Answers
SOURCE: Slow to spin and making a loud noise.
Control boards don't growl, the fry out and die. Sounds like a drive train problem to me. If it's a front load machine, the spindle/bearing assy. has gone to washer heaven. If it's a top load machine... could be the transmission, brake/clutch assy. or the tub bearings. In either case, if it's less than 5 years old, the drive system will be warrantied through the manufacturer. If you could provide a make and model number, I could narrow this down to a fine point.
Posted on Jul 29, 2007
BADBOYJAY
  • 264 Answers
SOURCE: LG Direct Drive WM-16220FD loud vibration during spin cycle
the pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
Posted on Jan 05, 2008
IFIXALL
  • 868 Answers
SOURCE: Maytag Neptune Front Load Washer
No, I'll tell you before forking out $ $ for some bad news.The noise is your bearing. You have to replace the outer tub .Its not going to be repaired any other way.The idiots who designed this washer made this a non servicable bearing.The labor is high not to mention the outer tub is also.REPLACE THE OUTER TUB.
Posted on May 19, 2008
Compaq makes short, loud buzz/click sound regularly?
The Laptop is New? One month old? Return it, it may be a bad HDD.
Mar 12, 2013 | Compaq Computers & Internet
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Our Kenmore Elite 45992 is making a loud squeaking sound when it spins clothes. We've checked the belt and shocks and they are okay. Any ideas?
Had same problem mine was the yoke thatheld inner drum tobearing was broken. Lucky it was covered by Sears warrenty. Over $1,000 to repair without warrenty..
Sep 30, 2012 | Kenmore Elite Washing Machines
I have an Amama NAV5800AW washer machine and about a month ago every time the washer is on spin cycle it makes a VERY loud sound, and lately has been leaking water during the spin. Any thoughts.
The noise you are hearing is the main tub bearing. Water has been leaking past the seal and into the bearing causing it to rust.There is no lubrication on the bearing anymore and you are hearing the metal on metal grinding. You are looking at a costly repair of about $350. I hope this helps you out.
Feb 28, 2011 | Amana NAV5800AW Top Load Washer
My machine is loud when sewing, not quiet anymore. It is an old Kenmore 14 model. I am able to sew,but the machine seems so be loud. I don't know if it needs oil or not. It so, how do I oil it myself?
Go sears parts direct and order a manual. It will tell you where to oil it. I am not familiar with a model 14. I think that you have to look at the nonclementure plate and get the whole number.
Jan 18, 2011 | Sewing Machines
Loading clicking noise on spin
Could be excuse me ..Bra wire in drum stick your head in and look, if so best way to remove is take out heater to fix only if you are confident in repair..Good luck
Oct 02, 2009 | Washing Machines
During the spin cycle, the machine shakes violently and dances across the floor. It has a loud squealing noise during this. My Performa is only about 14 months old. This is very disappointing for a Maytag.
Look in owners manual. I think these washers have a 1/2 hp. variable speed motor. make sure the washer is level from front to back and side to side, if its not that could be the problem. The motor has a lot of force, the squealing could be a bad bearing not sure.
Aug 24, 2009 | Washing Machines
Frigidaire front loader makes banging noises in spin cycle
hi there.......if this problem has just recently appeared...its quite possible that 1 of the tub suspension springs has broken resulting in the tub lying at an angle and causing this unbalance....you can check this by tilting the machine and looking at the tub susension points
regards Sir Galahad
Aug 16, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
