ASI - CL51-15 PC Notebook
Problem for ASI - CL51-15 PC Notebook
Where to find the CMOS battery
By shango on Oct 27, 2006
I can't disassemle this notebook to find the CMOS battery.
I took of all the screws, remove everything that should be. half open the lid but can,t take it off totally to find the CMOS battery witch I need to remove to reboot the computer due to some virus issue.
Can somedy help?
Comments:
Oct 27, 2006
- Thanks for your post,my problem is to find the CMOS battery because I can't even enter setup to change the boot sequence!
I will take care of the virus issue after.
Same Problem
Mar 17, 2008
-   I have notebook fmv-6700mf9/x, fujitsu. I cannot enter set up to change the boot sequence.
-   Guest
Dec 13, 2007
-   I suspect the CMOS battery on 2 CL51 laptops - can anyone tell me how to find/replace it? Any chance of a sercice manual?
Thanks, Tony Castles me@tonycastles.com
-   mrmotorvator
Best Solution
posted on Oct 06, 2007
Very Helpful)
imborntowin
Rank: Apprentice
Rating: 98%, 3 votes
After a long search, I finally found the CMOS battery of my Armada E500 where I was expecting it the least: under the power buttons bar, attached to...guess what...the inverter!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 27, 2006
Somewhat Helpful)
sandrew
Rank: Wiz
Rating: 83%, 5942 votes
Removing the cmos battery, won't address your virus problem, as you probably know it will only reset your initial boot up and not alter any software virus, unless you have an unusual bios virus.
Was this helpful?
Yes
No
Solution #3
posted on Aug 24, 2009
Very Helpful)
4drian
Rank: Apprentice
Rating: 100%, 2 votes
take out the keyboard from the bottom side with a flat screw driver under it there´s a few screws take it out lift the cover and there is the battery.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Jun 06, 2009
Very Helpful)
cabbagerun
Rank: Apprentice
Rating: 100%, 1 votes
Note most new computers no loger use cmos watch type batteries. They use rtc or real time clock batteries.
Had a problem with my gateway mx6025. I reset the bios password and just put spaces and then saved and exited bios. When i loaded up the computer the password screen loaded. I put in spaces and i could not get in. I tried the old password and could not get in. I called gateway to see if there was a default password and they could not help me either. After about 3 hours i finally figured out what to do. I know this sucks but I tried everything else first. (cmos password restore software would not work) Take apart the laptop and lift the keyboard. See your manufacturer info for this. Mine was here: http://support.gateway.com/s/Mobile/Q106/Blade/8511418.pdf
There is no need to remove the keyboard cable from the clip just move the keyboard aside
With the laptop open facing you, there is a round capacitor on the bottom right of the keyboard. It has a red and black wire connected. Lift up the capacitor, it is only connected to the motherboard with tape. Unplug the red and black leads from the motherboard via the white connector clip. Wait 5 minutes. Put everything back together and reboot. No more password!! Remember to reset the clock because it will be behind by 5 min.
Was this helpful?
Yes
No
Solution #5
posted on Nov 02, 2006
Very Helpful)
Logicart
Rank: Apprentice
Rating: 97%, 3 votes
To remove the upper plastics to get a t the cmos battery,you need to remove the 4 screws holding the screen in places. They are visible by the hinges. (That is if you have already removed the rest of the obvious screws).
Was this helpful?
Yes
No
Solution #6
posted on Dec 02, 2007
Somewhat Helpful)
country42740
Rank: Wiz
Rating: 80%, 452 votes
here's a good guide to help ya with finding the CMOS Battery:
http://www.irisvista.com/tech/laptops/To...
But will not help ya with the virus, what kind of virus does it say you have ?
Comments:
Dec 02, 2007
- Shango, Thought id add this about the virus : Download and install antivirus software (recommended norton, symantec, avg) and keep it activated on the pc. You can download latest virus definations this will protect ur pc from latest viruses..
Was this helpful?
Yes
No
Solution #7
posted on Jul 11, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
battery is under keyboard on presario 2580
Popular Solutions for ASI - CL51-15 PC Notebook
Questions and Unsolved Problems for ASI - CL51-15 PC Notebook
Do you recommend ASI - CL51-15 PC Notebook?
Answer
Answer
I have a HP PSC 1510 ALL IN ONE. EVERYTIME I TURN ON THE PRINTER IT MAKES AN ALIGNMENT COPY. hOW CAN... (More)
Answer
labtop acer aspire saya LCDnya terkena air. bagaimana cara menghikangkan air yang berada dalam LCD... (More)
Answer
Dvd drive wont work
Answer
My Acer travelmate 2492wlmi wont detect or play DVD's/CD's anymore. Even when I go into My Computer... (More)
Answer
No detecta ningún dispositivo USB, al parecer estan desabilitados desde el BIOS, pero tiene... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For ASI - CL51-15 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
