Question about Saws
What /or where on this BOSCH: 1581 VS -- to find access fro replaceing.
I have not used the BOSCH: 1581 VS, in a 3 years.. please
advise, Many thanks
  • toki708 Dec 20, 2008
    I there a screw down in the hollow shaft of the plunger. When I look down the hollow shaft all I see is the top of the blade. I can get it in and out, but there doesn't seem to be any screw to turn. Advice...?
  • 132 Answers
Hi there is a hole on the top of the handle at the front when holding it it is just in front of your hand you need a long series flat head screwdriver to loosen turn the blade sideways and out she comes
hope this helps glenn...........
Posted on Dec 15, 2008
Posted on Jul 03, 2009
Bosch b4300 jigsaw blade replacement
To change the Bosch B4300 blade - If the grey knob does not turn to release the broken blade, you need to use a LONG THIN flathead screwdriver down the center hole at the top. Unscrew until the broken blade is loose. Pull out. Replace the new blade and then screw the it tight through the same hole at the top. DONE.
Jan 25, 2012 | Bosch 1581AVSK Top Handle Jig Saw Kit
I have a bosch 1587 vs jig saw i got used. I don't know how to install a blade. I have never had one like this. I turned the top handle the way the diagram showed but I don't think something is working.
In most models at the blade shuck holder is a screw that thigh the blade,unscrew it and change your new balde .
Also Go to this LINK and find the part/diagram that can help you.
Please thumbs back if help is fine,thanks!.
Nov 02, 2010 | Bosch 1587avsp Vs Orbital Jigsaw
Replacing blade?
at the top and front of the saw there is a plastic handle. Pull up and rotate counter clockwise 1/2 or full turn maybe more. remove and replace blade and rotate clockwise (handle) and push it back down.
Jan 03, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
Bosch 1581 old style, blade is tightened with a screw driver. The screw to tighten the blade is lost. How to get part for an old style saw or have it repaired?
go to and you can order online or find a Bosch center near you the part number is 2 603 400000 and it lists for 1.20, let me know if you need more assistance.
Dec 30, 2009 | Bosch Saws
I bought used Bosch-1581-vs, unfortunately parts are missing required to secure the blade. Would you be able to tell me part numbers I need to buy? Thank you in advance.
The only clamp part you need is 2603400000 . It may be down in the shaft already. You need a thin flathead screwdriver to stick in the hole at the front of the handle. This is the bosch part number for their screwdriver for this jigsaw JA1001 .
Sep 15, 2009 | Bosch Saws
Do not know how to replace blade in a Bosch 1581 VS Jig Saw
You need a long shafted flat head screwdriver that fits into the hole in the handle above the blade. Then simply loosen or tighten the screw inside there, and the blade twists 90 degrees and will pull completely out. Reverse to install. Also see pg 7 of instruction manual (click here.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks
Jul 27, 2009 | Saws
What's the model number of that saw?
If it's one of the old ones, a 1581 VS or some such, you need a long thin flat-head screw driver that fits through the hole in the top of the handle and reaches down far enough to unscrew (loosen it) the set screw that holds the blade locked in place. Then you twist the blade 90 degrees (perpendicular to the direction of cut), and pull it out. Reverse process for installation, making sure before you tighten the blade it rides in the groove on the guide bearing below.
If that doesn't seem like it's the correct sequence for your saw I apologize.
The Bosch website won't accept any 10 digit tool product numbers due to some glitch in the system, and they made so many variations on that saw it'd make your head spin.
That's the other way some of them loosen up, actually, is by pulliing up the plastic head at the top of the handle and unscrewing it a few turns to loosen the blade.,, Vice versa for install..
Hope this helps a bit!
Mar 14, 2009 | Saws
Blade won't stay in jigsaw
It sounds like you need to replace the shaft.
Feb 22, 2009 | Bosch Saws
Blade Change for Bosch 1581
the screw is a flat head but you need a long series screwdriver you have to loosen the screw first then turn the blade sideways remove then place new blade in sideways turn to straight then tighten screw again its not too hard at all best of luck glenn.......
Nov 11, 2008 | Saws
Saws Logo
5,076 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
