My dj mixers crossfader is not sensitive in the right range. i am looking for a replacement which is either adjustable or sensitive throughout. vestax mixer mdm 410
  • 1 more comment
  • selekta Nov 10, 2008
    thanks for responding. my first time here. the crossfader on the mixer is replacable and it has no adjustment ( none that i can see anyway). all of the sound activation is on the extreme left and right 10mm which means that there's a huge mid section that does nothing. what i want is either a fader that responds from the centre position (gradual curve ) or maybe there is a modification to found for mixers of this nature ( with no curve adjust). what do you think? regards, ray.
    thanks for your input on that, its a new mixer, crossfader should be o.k, i suspect that this model is just that way . i'll keep diggin' though .
  • Graeme Ross
    Graeme Ross May 11, 2010
    hi
    Are you scratching and need faster fade? let me know
    regards
    robotek
  • 1,512 Answers
Hi Ray
Sounds like the fader has reached the end of its life. It should fade smoothly from one side to the other with equal audio from both lines in the middle. . You can get adjustable rate faders, but not for this model. if you do a search for a replacement (click here) there are plenty of places around the world to source one from. They are easy enough to change, overpriced in my opinion, but they dont miss you when it comes to replacements. Changing the fader will fix your problem I am sure. Thanks for using fixya. Good luck
regards
robotek
Posted on Nov 10, 2008
  • Graeme Ross
    Graeme Ross Nov 10, 2008
    you need to go for a pro type mixer to get the setup you seek. Sorry, you never said it was new, or I would have assumed otherwise. Just when you said there is section in the middle that did nothing, I thought you meant no audio! It is a little clearer now. the type of fader you need is this but it wont fit the model you have, only the pro range type mixers. I was going to suggest this tpo you, but I misunderstood your problem...
    regards
    robotek
HOw do you use the crossfader if all your music is coming through one port???
The crossfader is to gently fade from one source to another. If you only have one, the crosfader isn't useful... it would act like a plain fader with one side being dead and the other at full volume.
Aug 06, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
What lube can i use to clean numark nuvj crossfader. i'm gettin a leak while using the fader.
Usually a "leak" from one side to the other is an indication of a cracked resistance element. The fader would have to be replaced.
I lube the faders on my mixers using CRC226 availablle in the electrical dept at Home Depot. Use sparingly.
Aug 12, 2010 | Numark Nuvj DJ Video Mixer
The crossfader won't gradually fade from deck to deck.
In the front of the IDJ2 system there should be a switch labeled "CF Slope." Switch it downward and you should be good.
Jun 02, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
I think my crossfader stop working for some reason. when im on side B i get sound then i slide over to side A and i still get sound from side be,,, all the assign are right also the bass mid and hi kill...
I suspect one end of the crossfader pot has broken from the element. The fader probably costs less than $5.
You likely will have to remove all the knobs and some screws to seperate the board with the fader from the front panel so you can replace the fader.
VERIFY the pot is bad with an ohmmeter before dis-assembling however.
You MAY be in luck. It looks like the cross fader has a connector which MIGHT allow you to remove it or certainly only a small board for replacement, seeing these take abuse.
It appears that the cross fader is a dual 100K type B taper.
Apr 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How do i set the control for the crossfader on the djx700
u should b able to use it so long as you change the mode from stereo to split, then you can just use the panel at the bottom that says "crossfader:" :P
Feb 11, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Whats a crossfader
The cross fader switches the source from one input to the other input. D.J.'s use them to fade from one song into the next one they are going to play when using 2 different turntables or 2 different cd players..
You did say in your question that you needed a crossfader.
Hope this helps Brittany.
What's the 721 stand for?
Dave
Jul 01, 2008 | Yamaha Mg8-2fx 8-Channel Mixer with...
Tapco MIX60 6-Channel Mixer
It does not appear to have a crossfader
Check this link for a closer look at the mixer. You can click the "larger image" link and get a really good look at it. Unless one of the knobs are a crossfader, but I always seen sliders as a crossfader. At least you can see it better here.
http://www.bswusa.com/proditem.asp?item=MIX60
Jun 30, 2008 | Yamaha Mg8-2fx 8-Channel Mixer with...
98 people viewed this question
 Grubhead
Grubhead
