My old thermstat has only two wires how can i connect it to RTH8500 honeywell thrmostat
  • Purgatory Dec 03, 2008
    my old thermstat has only two wires how can i connect it to RTH8500 honeywell thrmostat
    Same issue with the RTH8500,
    I have a forced air gas furnace and only two wires going from the unit to the old thermostat. (don't rightly know what colors they are as the wiring from the furnace to the thermostat was a hack job splicing 3 different lengths of wire together)
  • 31 Answers
Do you have heating and cooling
Posted on Nov 16, 2008
Ct87n thermstat is hooked up and the heater is on because i smell the heat but it is not blowing out the vent
The blower motor isn't running. At the thermostat, red wire to the R terminal white wire to W terminal.or W2 If the blower still doesn't run It's probably not the thermostat.
Nov 07, 2014 | Honeywell CT87N - Round Heat/Cool...
Honeywell wiring diagrams
WE R GOING FROM A HONEYWELL TAYSTAT500 THERMSTAT (HEAT PUMP) TO A NEW HONEYWELL to (WHOLE NEWHEATING/AIR CONDITIONER) WITH A HONEYWELL RTH8580WF1007 THERMOSTAT? WHERE WOULD THE C WIRE BE. WE DO NOT HAVE A WIRING SCHEMATIC FOR THE OLF THERMOSTAT. IT HAS 7 WIRES. HELP?
Jan 10, 2014 | Heating & Cooling
I bought a Honeywell RTH8500 thermostat and I can't get the temperature to go down past 75 degrees
You will need the installation book that came with the thermostat. There is a way to enter into the programming of the thermostat from the home screen. From there, you will need to find what code is the temperature settings in the manual, they are usually all 3 digit numbers. Once you find the code for the setting your looking for which is the lowest temp for the thermostat, it will have a 75 to the right of it which you can set a lower number. Sorry I do not have the manual right now to just tell you exactly how, but hope this still helps!
May 28, 2012 | Honeywell Rth8500d 7-day Touchscreen...
I had a Honeywell Thermostat RTH8500 installed by a pro to run Heat / Cool electric heating WITH central air conditioning. Problem : When running on cool Fan on auto ,it work OK but sometimes when the...
Is this a new hvac system? A new furnace can work differently than your old one. Does it shut off after a minute or two or continue to run? If it continues to run then call that professional back and let him fix it. If it shuts down after a minute or two then it is a feature of the new thermostat to squeeze all of the cool it can from the a/c coil and ductwork.Some of them have settings that you can adjust for blower delay on and off, read the manual that came with the t-stat and see if it does.
Jun 16, 2011 | Honeywell Heating & Cooling
How can I unlock this th
Remove the thermostat from its base and replace the batteries. To remove the thermostat, grasp it at the edges and pull toward you. The batteries are on the back of the thermostat housing.
Read more: How do I Unlock the Digital Display on a Honeywell RTH8500 Thermostat? ' eHow.com http://www.ehow.com/how_7267447_do-display-honeywell-rth8500-thermostat_.html#ixzz17KTxLwBU
Dec 05, 2010 | Honeywell Heating & Cooling
Updating old honeywell thermostat with a new honeywell thermostat
check in the unit heater to see what is hooked up most only need to have red from transformer white to call for heat and green to make the fan run in man and somtimes common usually blue or black
May 09, 2009 | Honeywell Programmable Thermostat Heater
Honeywell thermostat
If you have a forced air furnace with an air conditioner attached make sure you have a jumper wire between Rh and Rc. If the Bryant thermostat had a wire hooked up to C you do not want to hook this up to Rc. Just cap it off and put it back in the wall or disconnect that wire down in the furnace.
Aug 10, 2008 | Honeywell Programmable Thermostat Heater
I can't program my thermstat
go to www.honeywell.com. There you will find a search tab. Type in the exact model number of your thermostat. You will be able to download the installation/owners manual.
Nov 29, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
