Heater makes a chirping sound ... all night long!
We have an older, out of warranty heater. It works well heat-wise, but makes a high pitched chirping sound, (I think) perhaps as it is clicking on and off with temperature changes.
  • Anonymous Mar 26, 2009
    same thing happening to my electric water heater tank
  • 375 Answers
SOURCE: Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Posted on Sep 13, 2007
Papa Chan
  • 56 Answers
SOURCE: Heater in dash makes clicking noise, stopped no heat
The clicking noise you are hearing is the temp door actuator. It is located in the center of the dash. If you look behind the radio from the Passenger side of the van you will see a white square box with a black or green connector in it. Remove the connector and then remove screws that hold the actuator in place. Install a new actuator and reconnect the wire connector. This should take care of your problem and your heater will be fixed. I hope this was helpful.
Posted on Jan 02, 2009
mrgrzz
  • 88 Answers
SOURCE: Lasko 5365 heater making growling sound.
sounds to me like you have a fan blade hitting something inside the unit, or the motor is going bad, thats the only moving parts to the unit unless it has a sweeping mode, moves from side to side, if it doesnt have that, then its your fan motor or blade, you probably need to replace the motor or the whole unit, as they are fairly inexspecive, but its your call, look inside the unit to see if anything is in there that might be making the noise as well, best of luck, hope that helped
Posted on Jan 20, 2009
  • 5 Answers
SOURCE: high pitch noise seems to be steering and temperature related.
I have a 2003 Ford Windstar also. You probably will need to replace the power steering motor. It will get worse, and if it goes out, it may lock up your serpentine belt, and you'll be on the side of the road.
Posted on Mar 31, 2009
papa_sanjay
  • 67 Answers
SOURCE: hard drive not working
physically hard disk head is crashed with the platter there is no way to rectify that
Posted on May 01, 2009
Frigidaire refrigerator only 6 months old making high pitch noise constantly after door has been opened. What is causing this?
Hello friend, thank you for your post!
Based off the information you have provided your Frigidaire refrigerator is making high pitched noises after the door has been opened. With our current refrigerators the new modern, high-efficiency compressors operate much faster than older models. The compressor may have a high-pitched hum or pulsating sound. If you feel that further assistance is needed please contact your manufacturer for any warranty coverage. -Matt
Feb 02, 2016 | Frigidaire Refrigerators
High-pitched chirp at same time every night
High pitch noises are very difficult to isolate. Since you have replaced the refrigerator, I would look for something else in the immediate vicinity that might be generating the sound.
Feb 16, 2014 | Refrigerators
My water heater emits a loud high pitched whistle when it is venting. Any ideas how to correct this?
I have an AquaStar tankless and it has started making that high pitched sound when in use. I wonder if that means I have clean the heat exchanger. I called Bosch but they won't help since it is installed in a bathroom--in violation.
Jun 21, 2010 | Bosch & Tankless LP Hot Water Heater
NO PIC & NO SOUND ONLY HI PITCH SOUND SURGE FROM BACK
Goto the site www.TvRepairKits.com and get their "chirping" TV repair kit. It will fix the problem of the dead set with high pitch sound or chirping sound.
Jan 01, 2009 | Philips 43PP9202 43" Rear Projection...
On off button blinking.
If your set is making a high pitch sound or chirping sound you can get a repair kit from www.TvRepairKits.com.
It will fix the no audio + no video + set makes chirping or high pitch sound.
Dec 27, 2008 | Philips 43PP9202 43" Rear Projection...
Samsung PCL542R Chirping noise
There is problem in sound IC. First check it
Feb 17, 2008 | Samsung PCL5415RB 54" Rear Projection...
No power just a chirping noise.
Chirping means the power supply is being loaded down by a short in most cases, likely a bad convergance IC
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 21, 2007 | Philips 60PP9352 60" Rear Projection...
Heating & Cooling Logo
977 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
