Question about Konica Minolta PagePro 1400 Laser Printer
Konica minolta 1400
I found this printer at a yardsale and when I try to print the paper goes in with no problem but it comes out all wrinkled and folded. What could be causeing this problem?
  • ups88racing Nov 10, 2008
    do you know where i can get some specs for this model? I tries to take it apart but the machine is so small it's hard to work on it.
  • 344 Answers
This page might help you:
http://kmbs.konicaminolta.us/content/support/supporthome.html
select your printer type and there should be information you can download.
Posted on Nov 10, 2008
  • 344 Answers
Sounds like there is something stuck (staple?) in the paper path. Having never seen this model of printer I can only guess. I would take a flashlight and look into the paper path.
Posted on Nov 09, 2008
Konica Minolta Bizhub C353 wrinkles all papers
Turn off & un plug your C353 tomorow much better it already cool you can easly performed the manual says.
Nov 07, 2014 | Konica Minolta Minolta Bizhub C353 Copier
Why is bizhub 450 is warping the paper after copying?
Have tech come out and look at the fuser unit and check the temp setings
Apr 25, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta 1690MF causing Fuser Paper Jam error when printing color. Does NOT happen when printing black and white. (Paper is genuinely stuck entering the fuser). Why is the problem happening for...
I was wondering if the original poster of this problem found a solution. My printer does the EXACT same thing. B & W printing is perfect. Any color print jams in the fuser. The printer feeds the paper too far (from thin copy paper to cardstock) so that the top of the page is cut off. Konica sent me a new fuser but that did not solve the problem. Again, this only happens when printing any page that has color on it (even a document with only one letter in color). B&W printing is unaffected.
Aug 27, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Envelopes wrinkles after running through printer
Minolta does recommend stuffing the lip inside the envelope before running. But I think it only helps with jamming. Plus high humidity can cause wrinkling.
Mar 14, 2013 | Konica Minolta Office Equipment & Supplies
Copies coming out wrinkled
Try cleaning the paper fed registration rollers with isoprophyl alcohol with fine cloth.
Dec 18, 2012 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta 5430dl wrinkles paper when printing. How do I fix?
suggestions= check the tray, that papers are properly inserted in the tray, papers should be moist free, this problem can also be caused by dusty pickup rollers, which picks the paper and also due to fixing unit problem.
Apr 21, 2010 | Konica Minolta magicolor 5430 DL Laser...
LOve my printer.BUT...the light goes to error as paper jam
Start the Konica Minolta Status application and check the error, you should get more info there.
Apr 02, 2009 | Konica Minolta magicolor 2400 Laser...
Media jam fuser
I turned the printer off, took the power cable out, and turned the printer on. After 60 seconds I turned the printer off, put the power cable back in and turned the printer again on. This is a solution in order to loose all the voltage/current build up in the printer. Whether this is the solution or just coincidental, I don't know. The printer worked well after that.
Mar 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Jan 13, 2009 | Konica Minolta magicolor 2490MF Laser...
Hi I have just reconnected my Konica Minolta Page Pro 1400 and installed the new cartridge - when I switch it on I can hear it start running and then it stops and the fan keeps going but the error light is...
In the user guide, a blinking error and ready light may indicate a communication failure and to make sure the printer cable is seated properly. Otherwise a blinking error light only indicates a media jam or no toner cartridge installed. For the media issue, make sure no paper is caught anywhere inside the printer. If the toner is the problem, try another cartridge. One of those should solve your problem.
Dec 01, 2008 | Konica Minolta PagePro 1400 Laser Printer
Konica Minolta PagePro 1400 Laser Printer Logo
199 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
