Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman 1/2 hp door opens only 8-10'' then stop
    President:
  • 3,197 Answers
Check your door springs. One of them may be broken. Also remove the cover and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped.
Posted on Sep 03, 2009
  • 672 Answers
Check to see if a garage door spring has broken. Operate the door by hand. If everything seems ok then increase the strength of the "up" force. There is an adjustment on the powerhead to do this.
Posted on Sep 02, 2009
Don't know Mod. No. lost installation manual, approx. 5 yrs. old Need installation manual.
About 496,000 results (0.43 seconds) Search Results
    [PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
    www.liftmaster.com/.../en.../tucmanuals/114a3044.pdf Chamberlain GroupFasten the manual near the garage door after installation. .... This garage door openerhas been designed and tested to offer safe service provided it is installed, ...
    Manuals Download Craftsman Garage Door Opener Model ...
    www.craftsman.com/search=manuals%20download%20crafts...
    CraftsmanCraftsman has the best selection of Garage Door Openers in stock. Get the Garage Door Openers you want from the brands you love today at Craftsman.
    Craftsman 1/2 HP Chain Drive Garage Door Opener - Sears
    www.craftsman.com > ... > Garage Door Openers
    Craftsman1/2 hp Chain Drive Garage Door Opener Opens by Remote, Inside and from Car Enjoy a great end to every day by ... Owners manual - English (Warranty).
    Free Craftsman Garage Door Opener User Manuals ...
Feb 03, 2016 | Building Materials
How do I update software
Feb 03, 2016 | Kenwood DNX-690HD eXcelon DVD Receiver...
I have a Craftsman/Chamberlain 1/2 hp 315mhz Garage door opener model 139.1845.DM just stopped working. The motor runs the chain moves, the door doesn't open. Whether I use the remote or pad still n
All garage door openers have a quick release. Have you checked to make sure that is locked in place? Most have a cord hangin from it and you pull it which releases it from the chain. Make sure that is engaged and it should work.
Dec 02, 2011 | Home Security
My Craftsman 1/2 hp garage door opener will go up fine with the push of any button but it starts then stops when I try to push the button for it to go down. It acts like there is something in front of the...
If the main light flashes 10 times when the door stops it is a door sensor problem. Make sure the small light on each one is lit and not flickering. If the main light doesn't flash you have either a bad IR sensor which is a small printed circuit board just in front of the motor or you need to increase the down force which is a control on the rear of the motor unit.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have an old craftsman 1/2 hp door opener. It
You may have a bad wall control. Try disconnecting it from the opener and try. Otherwise it is time for a new model.
Apr 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming kepad for Sears Craftsman Garagedoor opener 1/2 hp
The only procedure I have ever followed is to press the learn button and then enter the code, and not do anything else. I think your last step of holding the button until the light goes out is clearing codes as fast as you enter them. Just stop after you enter your code and let the learn mode time out on its own. That should do it.
And don't put your head through the wall. It just causes more headaches.
Feb 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door sometimes stops during run as if sensor is blocked
wipe off the sensor glass with a isopro rubbing alcohol; it should fix it.
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
63 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
