Question about Philips 32PF5320 32 in. HD-Ready LCD Television
Signal Problems I recently moved and set up my 32PF5320 32. The problem I've got is that the TV appears to be receiving a signal from somewhere that prevents me from using any menu functions on the remote. For example, when I try to lower the volume, the signal that the TV is receiving pushes the volume up to the max (99). Another example is that I tried to adjust the brightness, same thing happened, the signal being received pushed the brightness control to the max. I had to turn the TV off in order to clear the menu from the screen. As it stands now, I keep the TV on mute and feed the audio through my receiver. However, it's getting annoying because I have to contend with both the mute and volume indicators remaining up on the screen constantly.
  • Chris Soldiew Oct 28, 2006
    I've also reset the unit by powering it down and turning it on while holding down the power button.
DVD RECORDER. AUTO SET UP WILL DOWN LOAD
AND RECORD BUT HAVE TO USE AUTO SET UP EVERY TIME
I WANT TO RECORD
Posted on Jan 21, 2008
SOURCE:
Incompatible video signal has received check output device settings
My guess would be that your PS3 has somehow switched the output settings. You can reset the settings by pressing and holding down the power button till it starts blinking. Try connecting it with your RCA cables to a TV and if that works try going into your settings and setting the PS3 back to HDMI.
I’m happy to assist further over the phone at https://www.6ya.com/expert/wesley_57e7f19c14a313b1
Jan 23, 2014 | Sharp Aquos Televison & Video
Hello! I recently moved my Toshiba 26lv610u-t from my father's place to my own. It was a short trip as we live across the street from each other. When I connected the cable to the TV, I found that all...
There are no analog channels anymore as far as I know, if you mean the channels that are local and provide an off the air signals, you need to connect an antenna for off the air signals, it may be possible that at your father's place the off the air signal was strong enough to receive them. Try going in to the menu signal type select "Air" to see if that makes a difference, of-course you will lose the cable channels until switch back to "Cable" .Hope this helps, KA
May 07, 2017 | Toshiba 26LV610U LCD TV
Lost Digital TV signal - now back but weak - any suggestions?
I would get someone to check the signal strength first.
Dec 07, 2009 | Televison & Video
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
SATELLITE DISH
Sure you can, if you have Dish Network go to the receiver and turn the TV and receiver on. Then press menu-6-1-1. This takes you to the point dish screen. You will come out with better results using a compass to find the azimuth the dish should be pointed toward and bore sighting the dish by pointing it in that direction. You then will need to move the dish in very minute increments pausing for 15 to 20 seconds after each move to ensure the satellite signal can be found. If you have ran a check switch prior to this and have lost all satellites you more than likely will not receive a signal until you run another check switch and have found the signal of at least one of the orbitals. If this proves to be to tedious and many times it will you can usually find an inexpensive signal pointing device at a store like Radio Shack. Hope this is some assistance to you. Let me know if I can be of additional assistance and thank you for using Fix Ya.
Oct 07, 2008 | Televison & Video
I`ve set up my philips digital terrestrial receiver DTR220 and i`ve scanned for all channels, but i can`t pick up any because my aerial is not picking up any signal. I`ve tried different, stronger aerials...
I actually moved my tele to the other side of the room to see if it would work in a different spot and it took me ages to get some signal by moving my aerial around. The signal still wasn`t strong and i didn`t have alot of the channels and then i turned it on a few weeks after and it was working perfectly. Don`t ask me why! :s
Jul 21, 2008 | Audio Players & Recorders
Indoor antenna problems
I don't know the menu system on your model, but you have to check that the tuner is in the proper mode. Also, some of the new TV set models cannot receive a standard analog TV signal from its tuner.
As for the distance from the transmitter sight, this depends mostly on the antenna quality, antenna location, the power output of the transmitter sight, compatiblity of the TV to the received signal, and also the capability of the TV's tuner.
Modern TV sets are really designed to be used with a satellite or cable TV box with their respective service.
Terrestrial TV is dying out, and in a matter of a number of years, it will be gone.
Jerry G.
May 24, 2008 | RCA F25645 25" TV
DIrectv Sat internal box.
You can try eliminating whethor or not the receiver is actually the problem by moving it to another TV and seeing if it works on one that isn't having any problems. Or moving a working receiver onto the TV to see if it will pick up signal with a working receiver. If you don't have any receivers in your house working, then odds are something needs to be serviced outside your home, like the Dish and/or LNB.
Did DirecTV actually come out to the home and troubleshoot at the site? If not, they would have no way of knowing if it's the TV or Satellite that's causing the issue.
Aug 09, 2007 | RCA F38310 38" TV
Philips 32PF5320 32 in. HD-Ready LCD Television Logo
180 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
