HP Photosmart c5180 Paper Feed Problem
I put clean paper in the tray but message comes back that there is no paper. I've tried cleaning out the tray and making sure it is locked into place, but still the same problem. Ihave a cannon ip 2600 .when I push print on my coumputer,my my printer goes though the sound that it is working but it don't.than apop up says I don't have paper
  • 1 more comment
  • dunmire Jan 18, 2009
    Having a problem with my HPc5180 printer. Keeps saying it is out of paper. Any idea what would cause this?
    Thanks for any help. L.D.
  • Anonymous Feb 24, 2009
    Same problem on C5180
  • stercuscaput Mar 04, 2009
    Let me offer another suggestion, I removed the paper and pushed all the way back and pushed the slider arm all the way back as far as it would go and it fixed my issue.  It seems like such a easy fix, but it appears my paper wasn't going back far enough.
On the printer, press the setup button, then go to preferences, the DPOF tray select, select main tray, then select the return button (bottom left from directional pad).
Posted on Mar 04, 2009
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
HP C4280 won't grab paper,tries then says out of paper
You need to clean the feed rollers. Open your HP Notification tray and check up some options. It's really intuitive so if you fiddle around a bit, you'll probably find an option to clean the feed rollers.
If not, dampen a cotton cloth and wrap it on a ruler and scrub the feed rollers yourself. Just look into the tray where you put papers and on the back you can find normally one feed roller on the right side. It's not that difficult.
Good luck.,
Feb 19, 2010 | HP Photosmart C4280 All-in-One InkJet...
Printer error to insert paper face down.
Have you tried cleaning the rollers, or resetting the printer? See here. For loading paper instructions, see also here. & here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 26, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C 7280 paper feed problem
check the feed tray is good, if so.
Clean the feed rollers,
Lint free cloth, distilled water.
Should be good.
Regards
Richard.
Apr 18, 2009 | Office Equipment & Supplies
Wont feed glossy photo paper
Clean the feed roller(s) with a cloth dampened with alcohol. They are probably slippery with paper dust.
Mar 17, 2009 | HP Photosmart C5180 All-In-One InkJet...
first of all power off printer
then after back side open tray. and clean all dust.
some time paper are jam or cut their so, printer sense paper still in their.
so do this u can printer again easy.
Nov 09, 2008 | HP Photosmart C5180 All-In-One InkJet...
Hp 3310 paper feed
Take off the back of the printer - there is a door running almost the full length which has a latch. Using regular rubbing alcohol and a Q-TIP(R) cotton swab, clean the little rubber rollers which grab the paper from the tray. The rollers you need to clean will be low and on the left as you look at the back of the printer and they are about 2 inches inside the printer. There are 2 of them. Paper dust builds up on them and they fail to grab the next sheet of paper, causing the error message. Works every time!
Sep 14, 2008 | HP Photosmart 3310 Printer
Paper error
It sounds like the photo paper tray has gone in.Lift the paper tray and pull the blue photo paper tray all the way till it stops. Then push it back in till it clicks into place. Try printing again.
Let me know if it works
Jun 10, 2008 | HP Photosmart C5180 All-In-One InkJet...
Can't Print
HP Paper Feed Cleaning Kit - Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00754199&lc=en&cc=us&dlc=en&product=439488&rule=584&lang=en
ou may not have the paper width set snug to the paper to feed correctly.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00553862&lc=en&cc=us&dlc=en&product=439488&rule=584&lang=en
Consult http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00601439&cc=us&lc=en&dlc=en&product=439488 regarding "out of paper" errors Paper cleaning kit is included in this article.
Apr 19, 2008 | HP Photosmart 3210 Printer
Computers & Internet Logo
607 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
