Question about Refrigerators
Want to clean Mold/Mildew out of ice & water dispenser
I have a GE TFHW22RA side-by-side refrigerator that has mold/mildew in the ice/water dispenser and flaps. Is there a way to disassemble it to clean it?
  • 2 more comments
  • kcknowl Dec 17, 2008
    can any one tell me to get ride of mold in my refrgerator
  • tjwaeghe Dec 22, 2008
    I have the same problem with water having gotten behind the plastic front on the ice maker lever. I tried spraying it on both sides with Tilex bleach spray and let it stand for a bit. I also tried moving it a little bit, as I couldn't remove it and didn't have the right tools to remove the center screw. The bleach spray seemed to work quite well and may leave a preventative layer of hypochlorite behind. We'll see. I then sprayed water from a spray bottle and switched to crushed ice and collected a few cupfuls of crushed ices to get the bleach away from food surfaces.
  • rainewolfe12 Mar 10, 2009
    My mold is in the water dispenser. I think it might actually be in the line. Can anyone help with this?
  • Anonymous Apr 20, 2009
    black mold/mildew specks on flaps, spouts in tough to reach place.
2 Suggested Answers
  • 1073 Answers
SOURCE: our ice tastes and smells
install an odoer filter on the fridges main water line
Posted on Apr 28, 2008
I have a Samsung front load washer WF316BAW. I clean dispenser drawer regularly,today when I removed the drawer I seen mold inside. How do I get rid of it?
Spray Tilex brand mold and mildew remover into the dispenser. Once you have let it sit for awhile wash it out with hot water.
Jun 29, 2017 | Samsung Washing Machines
Mold growing around ice dispenser area. Cant figure out how to get to the mold .
Pull ice maker out and clean it. Then make sure you have a fresh water filter on water supply. Mold in the freezer is uncommon if its truly freezing inside. You have dirty water coming in.
Oct 13, 2013 | GALAXY Microsystems 25.4 cu. ft....
Ice production is very low
You should clean the coils beside the compressor. That helps.
Maybe think about replacing the water filter.
That ice maker makes 3 attempts to fill the mold. It's on board intel monitors changes in resistance when water is added to the ice mold.
Learn more about how it works HERE
Bonus stuff: HERE
May 24, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Cleaning internal humidifier
Try using vinegar and distilled water.
If this does not work try using a little bleach and water. Repeat till mildew is gone.
Rinse thoroughly Again & Again.
Everyday humidifiers should be cleaned.
After your last uses try blow drying it. Before you put it away. If it's dry it will not mold or mildew.
Mold & mildew will cause you to get very sick.
If the mildew does not go away replace your unit.
May 19, 2010 | Humidifiers
I have a IM-4A and it continues to dispense water without making cubes...possible solutions please
Check to see if there is water/ice in the ice mold of the ice maker. If the mold is dry, you probably need to replace the water valve.
Nov 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
How to clean where ice & water come out on a Hotpoint side by side. It appears to have mildew I think.
You can disconnect the water line at the bottom of the freezer door and using somthing like a turkey baster or one of those baby nose bulbs, pump a water and baking soda and bleach solution through it. Let it sit to kill the mold and rinse throughly.
Aug 16, 2009 | Refrigerators
Smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
1,632 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
