Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
I have red burn/sun spot growing larger on my hitachi 50v500 what is the problem
  • 1 more comment
  • mnapitn Jan 05, 2009
    I have the same tv with the same problem..Whats up with that can anyone help a sista out???
  • clearmnt Feb 14, 2009
    same thing also losing sharpness in hd
  • pierces Feb 18, 2009
    Thanks for your input; I've had the same problem of red spot for about 6 months; TV is only about 2 years old.
    Problem Solver:
  • 4 Answers
I have the same problem and just got off the phone with Hitachi. explained my problem and that I had read similar posts for this web site. Hitachi rep was very courteous and said that after I had set evaluated by any authorized repair shop, they will ship part needed for repair. He even gave me the name of an authorized shop in my area which I call to set up an appointment($40 charge). Called and made service appointment and person I spoke to said based on my explanation problem is probably light engine and if so labor cost to replace would be around $300 but he added part was very expensive so I guess I can't complain since set is out of warranty. Hitachi # is 800-654-7013. Suggest you have model and serial # handy when you call. Recent lawsuit filed against them may be the reason I encountered no resistance by Hitachi. Thanks to all who posted suggesting this tactic.
Posted on Jan 30, 2009
Large red spots growing in the middle of my 50v500 hitachi projection LCD screen
Hi, you have an Optical Engine fault. Complete assembly needs to be replaced. This page shows the most common Hitachi Optical Engine Faults.
Hitachi LCD TV Light Engine Optical Block Info
Nov 27, 2015 | Hitachi Televison & Video
My Hitachi 50V500A has a large area where the color is turning out to red. Is this a lamp or a complete light engine replacement job?
not the lamp. hitachi knowingly had a defect with the fan not allowing enough air to cool the lamp which has burned the red color lense resulting in the red on your screen. enjoy your new brick thanks to hitachi!
Jan 09, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
Model 50v500 a red glow in the center
check for the yoke coil, might burn or open.
Apr 05, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50v500 LCD, at the center of the screen there is a lighter spot than the rest of the screen,about a 10 inch diameter circle. Is this a bulb problem.
If it is a redish oval it is not the bulb. Go to a black and white program and take a good look.
If it is the red or pink oval let me know and I will tell you what the problem is.
If this helps you rate this solution as I do this here for free.
SD TECH
Jan 09, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Same problem
The red death as its called.
Very common in the 50v500 and 50v700 series.
it is caused by a blocked filter deep inside the TV, nearly inaccessible.
The LCD panels overheat (red one or blue one) and the light engine needs to be replaced.
You are better off living with it unless you have a warranty.
Sorry it wasn't better news.
Jul 09, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue spot and burned images on my hitachi 55vs69.
Bad Light Engine Call UED 1-800-648-6657 ask for rebuilt.
Dec 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
Help
I see a very large red spot on my screen now. I just replaced the lamp and it seem OK. Now I get a large red spot with no indicator lights. Is there a pending problem?
Sep 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 Red Spot
Deb,
Unfortunately if you're not a technician Hitachi won't even consider sending you a LE for install... They will confirm your status and have you fill-out several documents.
As to the other part of the question, the service manual won't help - there is a procedure for memory re-initializing and after performing that you still have the spot then LE is called for.. But again, unless you're a tech with those letters behind your name Hitachi won't accept the results.
That said, we have done several of these and Hitachi has been exceptional to deal with pre and post install.
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Aug 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50v500
Email me privately and I'll send you the asc data sheet directly from Hitachi... Make sure to give me enough information about this to jog my elderly memory - I get between 3-5 thousand emails a day...
Bill
premtech@willapabay.org
Nov 15, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
TV Problem
It is a failure in the light engine itself. You will need to have it replaced. Here is a link to that rather costly part. http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/50V500/Hitachi+Ltd/Hitachi/UX22201D/New.aspx
Apr 05, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
114 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
