Question about Dell Latitude D600 Notebook
Dell Latitude D600
Won' boot up. Ran diagnostic came up with error code 1000-0145. Please Advise
  • titan85 Nov 10, 2008
    Thank you. I diagnosed via BIOS. Tried rebooting. Upon restart I recieve the following:
    Hard disk read failure-
    No bootable devices--strike F1 to retry boot, F2 for set up utility
    Scholar:
  • 35 Answers
It is the Hard drive on the system. Hard Drive is failing. Another Error code for the Hard Drive is Error Code 7. Check BIOS setup if the system still detects the Hard Drive as well. You may want to consider changing the Hard Drive on the system.
Posted on Nov 10, 2008
Computer boots up but then goes into a black screen I have run a Dignostic on it and I get an DST Short Test Error Code 100-0146. This is a Dell Latitude D600. Thanks In Advance
This error indicates that your hard disk drive or the circuitry that controls the hard drive is defective.
Either your hard drive is defective or the motherboard.
Try running diagnostics form a CD on your computer. You should have a CD that came with thecomputer that has "Diagnostics and Utilities" listed under contents.Boot form this CD and run the extended diagnostics.
If you don't have the CD you can go to www.support.dell.com andselect "Drivers and Downloads". Enter the "service tag" (serialnumber) of the computer. You can then download "Diagnostics" .
To boot from a CD disk, power on your computer and tap the key tobring you to the "One time boot menu". Insert the CD into the top CD/DVD driveand then select "Boot from CD/DVD" and hit key. Select the"Run the 32 Bit Dell Diagnostics.
If you are able to run the Diagnostics then your hard drive is probably defective.
Aug 02, 2011 | Dell Latitude D600 Notebook
DST log contains previous errors.DST short test failed
Error Code: 0146
MSG Code: 2000-0146
MSG: 1:DST Log contains previous errors
Dec 22, 2009 | Dell Latitude D600 Notebook
I'm getting a stop error code 0X000000ED,0X86714368, 0X0000006, it's on a Dell Latitude D600 laptop?
Unmountable boot volume indicating that the system cannot successfully read the boot sector of the hard drive.
Run the diagnostics on the hard drive, if it fails, replace the hard drive.
If diags pass, boot to the recovery console, run chkdsk /r If it still gives the error after that, you can try reinstalling windows.
If that fails to resolve, then again, replace the hard disk drive
Nov 19, 2009 | Dell Latitude D600 Notebook
Dell "Drivers and Utilities" CD
NEEED TO GO INTO CMOS SET EVERYTHING UP DATE THE HARD DRIVE , CD ROM, DVD, FLOPPIES DRIVES,HD DISK, HDS, CYCLDR, SETORS,
C-MOS BATTERY MAY NEED TO BE REPLACED,
ROD
DRIVERS
WWW.DELL.COM/DRIVERS
WWW.MOTHERBOARDS.ORG
WWW.MRDRIVERS.COM
WWW.DRIVERSHQ.COM
WWW.TOMSHARDWARE.COM
WWW.WINDRIVERS.COM
ROD
GO ON LINE AND TYPE THE FOLLOWING;
DELL LATITUDE D600 DRIVERS
OR
DELL INSPIRON 1150 DRIVERS
ENTER
ROD
Feb 10, 2009 | Computers & Internet
UNABLE TO BOOT DELL D600 - FAILURE TO DETECT HARD DISK
If you press F12 during bootup, you should get the boot menu. Run the hard disk diagnostic. If the hard disk is bad, you will get a DST Short Test Error code.
Replacing the hard disk in a D600 is a piece of cake though so if you need a new HD, it's easy to do. The tedious work will come afterward.
Dec 31, 2008 | Dell Latitude D600 Notebook
Dell latitude d600
Greetings AROD718,
This error message is telling you that your hard-drive is nearing OR has already failed.
I would contact a buddy or go somewhere local to get Data recovery ASAP or if that is not important to you start shopping for a new hard-drive.
Hard drives are not very expensive and are simple to install, if you need further assistance please reply back!
Good luck,
Shawn
Oct 31, 2008 | Dell Latitude D600 Notebook
Hi, the "No Diagnostic Utility Partition Found" is returned because your laptop does not find the recovery partition on C drive.
Easiest way to create partition is with dell recovery cd. You can buy CDs from dell, buy finding contact on web site or buy from one of the following.
Dell Restore Disk: XP Pro SP2 for ... $35.00 - DIMOSOL - Digital ...
Dell Latitude D600 XP System Recovery CD ... $18.95 - recovery-cds.com ...
Dell Latitude D600 Vista System Recovery ... $18.95 - recovery-cds.com ...
Buy recovery cd according to windows version on sticker at the back of your laptop.
With recovery CD you wont need drivers.
Alternative solution is downloading drivers posted by Maanita after installing Windows from a generic Windows setup CD.
Aug 13, 2008 | Dell Latitude D600 Notebook
Does not boot up
my laptop is very slow why?
Mar 17, 2008 | Dell Latitude D600 Notebook
Dell latitude d600 not booting/blank screen
well what you have on your computer is the computer does not find your hard drive where you have the operative system thats why is asking you to boot from cd because the computer wants to instal a operative system may be your hard drive is damage ok lets do a test turn on your computer by presing the power botton and then press the key to boot on bios page can be (delete ,F1, F10 ) any of those every time you try to do the boot up if does not go to bios you have repit the same operation so when you get bios system display on you computer look for the hard drive and the boot order if there is no hard drive so your hard drive is damege and you have to reolace for a good one and instal the operative system
Dec 29, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
636 people viewed this question
Alun Cox
