Question about JVC GY-DV5000U Mini DV Digital Camcorder
"No DV Input"
I recently had a problem while on location: we were taping but something was going on because the counter was not moving and "no dv input" flashed on the viewfinder/LCD monitor. Has anyone had this particular problem before? We turned the camera on and off and it worked for a while before it freaked out and demanded a head cleaning. Any ideas? This option is not in the manual and I have not been able to find this phrase by searching on the net. thanks!
  • 71 Answers
Get a head and path wet cleaning and reset and recheck again
Posted on May 03, 2007
Dear Sir/Madam, We are actually looking for some professional help. We are a religious organization, and currently shooting our events with Sony PD-170, using sony normal mini dv tape and Panasonic...
Some of the tapes that we get can be problematic so, if you want to record professionally like the TV studios do. Here is what you must do so that you do not lose the information on your tapes. Some of the bad news is that you can not recover anything from your DV tapes if nothing was recorded on them. However the way forward from now on is to record black on your tapes before shooting on them. Here is what you do. Buy a new tape or if you want to use a used tape you do the same. You insert your tape in the camcorder, with your lens cap on that means you do not take your lens cap off and then start recording. What you will be doing is laying black on your tape so that it becomes ready for recording. It means that your tape will now be recorded with black. you can then rewind and start recording with your cap off the true recording. The tapes will not then be problematic. Please let me know if this has solved your problem.
Oct 28, 2011 | Sony Dvcam DSR-PD170 DV Digital Camcorder
DVD to mini DV tranfer
Only way is Play burned DVD in dvd player and provide Audio- Video out (yellow-red-white) to mini DV camera that has AV Line Input recording facility. Or find any Mini DV recorder and record tape.
In that way you can record video again on Mini DV tape.
Apr 24, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Panasonic AG-DV2000 Mini DV loading problem
the "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure for the inexperienced.
Oct 11, 2007 | Panasonic AG-DV2000 Mini DV VCR
DV tapes will not load
the "dv sensor"is actually a mechanical lever built into the cassette housing that moves the reel tables to match the reel spacing on mini or full-size DV tapes. check to see if this assembly is free to move. if it binds up, the reel tables may not move as far as they need to, and can cause problems similar to the one you're seeing. to inspect the mechanism, you need to remove the cassette housing. if you don't have a service manual, get a tech to help -- it's a delicate procedure.
Panasonic AG-DV2000 Mini DV VCR will not play large DV tapes
Aug 14, 2007 | Panasonic AG-DV2000 Mini DV VCR
the problem of your player is the mechanism to dv tape slut(not mini dv)...it need to calibrate or to tune up...only can fix this is a qualified technician....
Won't play DVCAM, will play Mini DV
it is probably matter of dirty guide so the timecode stop reading try a wet head cleaning tape to play it there regards please don't forget to rate ,thx
Feb 20, 2007 | Sony DSR-45P DV / Mini DV VCR
Connection using Firewire
Use a DV cable to connect the camcorder to the computer. Determine whether your computer has a 4-pin or a 6-pin DV terminal. Use an appropriate, commercially available DV cable for your computer's DV terminal. When making this connection, the use of the compact power adapter is recommended. How to connect ? 1. Turn the camcorder's POWER switch to . ? 2. Move the TAPE/CARD switch to . ? 3. Connect the computer's DV terminal and the camcorder's DV terminal with the DV cable as shown in the image below. The location of DV terminals differs between computers. For more information, please refer to the documentation that came with your computer. Important: 1. Operation may not work correctly depending on the software and the specifications/settings of your computer. 2. If the computer freezes while the camcorder is connected, disconnect and reconnect the DV cable. If the problem persists, do as follows. (1) Disconnect the DV cable, and then turn off the camcorder and the computer. (2) Turn the camcorder and the computer back on and reconnect them with the DV cable. 3. The image files saved on the hard disk drive of your computer are original data files. If you wish to edit these image files on your computer, make copies of them first, and use the copied file, retaining the original.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
JVC GY-DV5000U Mini DV Digital Camcorder Logo
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
