Question about Bose in-ear headphones - Black with black/white cord
Can bose wires be splice?
Faulty contact on end of jack. Cut open, three color of wires, green,red & yellow. Is there a repair kit jack, perhaps at Radio Shack???
My cat chewed my bose headphone wire in two. Can the wire be spliced back together?
Posted on Sep 05, 2009
Trying to connecting my Bose lifestyle to my Samsung led smart tv to play a DVD with a yellow video cord and picture is blurry and double and has jo color? Any ideas how to fix Bose lifestyle is older...
Without the specific LifeStyle model # it's not easy to say for sure, but it sounds like you might have a composite cable plugged into a component video output of the Bose. Assuming it does not have HDMI output, it might have white/red/yellow (RCA-type jacks, aka "phono") and that yellow jack is a composite video output. It would plug into the same color jack on the TV. There are also RGB (Red/Green/Blue) component outputs on many devices and similar inputs on the TV, so you have to match like color out to same color in and make sure the TV is set to composite video input, not HDMI nor component.
Also could just be a bad cable. It's always the cheap things that we overlook, so with the same output/input setup, assuming you match type, try a different cable. The actual color of the end on the cable does not matter, but don't plug a yellow-colored output jack to a red, white, blue or green input jack on the TV - that won't work.
Feb 18, 2015 | Samsung Televison & Video
Where is the power distribution center for the blower
This is a common failure on 1999-2004 WJ models with the AZC (Automatic Zone Control) system. The connector on the blower motor control module overheats, resulting in intermittent or no operation of the blower motor. Mopar released a connector harness repair kit to fix the problem. The damaged connector is cut off and new wires are spliced into place. Only the green wires from the kit are used. One end of each of the 3 green wires goes into the new connector end that is provided. When inserting the wires into the connector, the locking spring tabs should be on the bottom. There is a gray plastic retainer that is then installed around the three wires that were just inserted into the connector.
Jun 24, 2014 | 1999 Jeep Wrangler
How to hookup a bose 321 to a toshiba 58l7300 tv
The Bose system does not appear to have HDMI output. The best-quality method would be to use Component (RGB) cables with analog audio. One RCA pair will be for audio and these are often RED & WHITE connectors, but don't have to be. Any RCA pair will work. Connect these to the Bose RED/WHITE jacks found in the "TV" labeling. Connect the other ends to the Toshiba's RED/WHITE jacks on the bottom row, first two jacks.
Now you need a Component cable. This has three RCA connectors at each end and are traditionally RED, GREEN, and BLUE. Again, colors do not matter as long as you connect the ends so they match. Under the "Component" labeling on the Bose, you will find the three colored jacks. Connect these to the Toshiba's same-colored jacks which are next to the RED/WHITE ones you used previously. These three connectors carry the video signals. They will transfer Hi-Def 1080i signals, not 1080p, but you wouldn't be able to tell the difference.
Switch the input on your TV to "Component".
Dec 29, 2013 | Toshiba Car Audio & Video
Splice Bose speaker to connect to receiver
Each speaker has two 4 Ohm drivers. Each speaker has a connector with 4 pins. From left to right they are + - - +. Say 1 2 3 4 . If you want a 8 Ohm speaker connect 2 and 4 together. Now 1 goes to your amplifier (+) and 3 to your amplifier (-). In yor case join black with blue. Now red goes to the amplifier red and green to the amplifier black.
Nov 27, 2011 | Bose Cinemate Digital Home Theater System...
Turned TV on and every channel is a red background. Unplugged, waited and plugged back in...nothing!!! Help!!!
If you are using the component input be sure all three wires green,blue and red are connected at both ends and are in the correct colored jacks. Component input is different than yellow jack which is composit video input. The 3 wirw component video in is progressive scan and all three wires must be connected correctly. Try this first if not replace the main board.
Mar 20, 2011 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Hey there I have Dell 5650 Computer Speakers i turn the volume all the way down but still get high sound from speakers someone please help
how long has this been going on? you can also turn the volum down on your computer look to the lower right corner of you monitor. you will see a little horn. double click it to bring up your volum control lower as needed
Nov 13, 2009 | Dell 5650 Computer Speakers
I opened the phone jack and found a continuous wire ( uncut ) coming into the jack and going out. Inorder to install a phone jack do I cut the wire and then wire it up via color codes? The outlet is in a...
Well if the house is built in the 70's the cable is old 2 pair wire, meaning that there are 4 coloured wires (red, green, yellow, black). If you cut the sheathing off (Carefully without cutting the cables) you can see the colours of the cables.
The first pair of wires to use are the Red and Green. The second pair of wires to use are the Yellow and Black.
If you hook up the red/ green wires to a voice jack, these cables might possibly be hooked up to the main telephone terminal (usually found downstairs) and you will have telephone service to the jack.
But not knowing where the cables are attached to this is hard to say.
Might be alot easier if you call in your telco provider to get them to install this jack.
Good Luck.
Oct 30, 2009 | Lands Phones
Wire broke right next to headphone jack; any easy way to fix?
if you are not handy, then no.
repair will require disassembly of the ear piece, splicing of the wire, and reassembly.
Sep 19, 2009 | Bose TRIPORTĀ® Headphones
I'm trying to install a rotary phone, but it doesn't have a jack like modern phones do. It has three wires with little crescent shaped metal things on the ends. Please help!
if they are red-green-yellow then just isolate your yellow wire and spade and open up phone junction box and connect the red/green wires to the red/green wires on phone jack terminals you can hook either way this type of phone isn't polarity sensitive,then make sure all other phones on this line work properly after install
Sep 15, 2009 | Cortelco 1950's Classic American Standard...
Wire has been cut
My wire was cut, and I made it worse trying to fix it....with several failed attempts... was becoming despondent, but gave it one last try, and was successful. First, each little tiny wire has two internal wires, one green (ground) and one gold (hot). At first, the green one looked like some fiber or filler and I cut it, connected the gold wires and nothing happened. On further inspection, with magnifying loopes, I determined the green fiber was in fact green wire. There was also a lot of clear fiber, which is insulation? filler?... I don't know, but I cut it out, leaving only the wires. From the internet, I determined that the wires had a thin layer of plastic on them for insulation, which I burned off lightly with a lighter, connected the green together, soldered it, wrapped in electrical tape, then connected the gold together, soldered it, and taped again....and to my suprise it worked. I used twist ties, and epoxy to strenthen the area and was done, my headphones are working again.
Nov 04, 2008 | Bose TriPort Consumer Headphones
Bose  in-ear headphones - Black with black/white cord Logo
2,023 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
