Question about Mitsubishi WD-65000 65" Rear Projection Television
Line down the cent of the tv
Well there is a line going strait down the center of the tv. it is about 1/4 inch thick, and has a scarmbled looking picture. I also noticed that when this problem started to occur, after the tv was off the tv's power light continues to flash on and off... please help . The lamp is pretty fresh.
    Sergeant:
  • 337 Answers
If all you get in the screen is this line coming down from top to bottom the set has a problem in the horizontal deflection circuit and it needs service,the lamp will never cause a symptom like this.If you are familiar with tv service you can give it a shot and look for the problem,it might be only a loose conection in the circuit I mentioned but if you are not too familiar you will need the help of a servicer.Let Us know if you need more information.
Posted on Oct 27, 2006
  • Omar Urrutia
    Omar Urrutia Oct 27, 2006
    Your rating response is also important.
I was changing the fuel line on my partner 950 and when i pulled the line out of the tank a round steel bushing fell out of somewhere in the tank . the reason i was changing the fuel line was because
This is the fuel filter weight, push the fuel line through the center flat side facing out, push the fuel filter onto the pipe, now pull the weight down on top of the filter this also crimps the pipe to stop the filter falling off
Apr 08, 2013 | Husqvarna Partner Gas Powered Cut Off Saw...
I have a inch thick black line down the center of my screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Aug 13, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Vertical line down the center, sound OK.
This is the deal. Your picture tube is going out. How thick is the line. As it gets wider that will tell you how much more time you have. Was the TV dropped? There is a way to adjust this but you have to get into the back of the TV and if the static discharge is not done properly it will kill you. Don't mess with it. It is now cheaper to buy another TV on craigslist or your local paper than trying to repair it. Hope this helps.
JimmyC
Sep 25, 2009 | Televison & Video
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
61 inch sony LCD projection
Optical block or LVDS cable You need a tech to tell you for sure, have a tech look at it
Sep 30, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
31'sanyo tv analog has a white horizonal line thru it
There is a failure in the vertical amp section. This can be the main output IC, or any of the support components in this area.
An experienced tech can troubleshoot the set, and determine and service the fault.
Jerry G.
Apr 27, 2008 | Sanyo DS31590 31" TV
Tv help!
When you have the back off, look for the flyback (high voltage) transformer. This is the part that has the thick red wire protruding from its top which attaches to the top of the picture tube with a suction cup. On the flyback there are 2 controls, the bottom one is screen and the top one is focus. Turn the bottom control (screen) down (counterclockwise) until the white lines go away and the brightness looks normal. Then turn the top control (focus) until the picture is nice and sharp. If the F connector has been pulled out and the TV has RCA (red, white, yellow) jacks, use those jacks and set the TV to INPUT.
Aug 13, 2007 | Zenith A27A11D 27" TV
Panasonic trouble
Without looking at the set I would think the problem was in the optic block. An expensive repair, but, since the set is only four months old it's under warranty. Go to the service section of Panasonic.com and find an Authorized Service Center (ASC) in your area to have the set repaired. Good Luck.
Apr 20, 2007 | Panasonic TC-26LX60 26 in. LCD Television
Vertical line splitting screen
We have had issues like this that ended up being the digital convergence module. There are surface mount electrolytics that suffer from dielectric absorbtion (dry out) and they must be replaced. It's much easier to replace the module than to repair it, the convergence will need to be reset once this is done. If you have the original remote control you can gain access to the service menu to reset the digital convergence. Joe Weibel
Feb 12, 2007 | Mitsubishi WD-65000 65" Rear Projection...
Mitsubishi WD-65000 65" Rear Projection Television Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
