Question about Konica Minolta magicolor 2300DL Laser Printer
Fatal error 21h; and problem printing even without the error
Problem one: konica minolta 2430 dl fatal error 21h. I think this happened before, and someone said to dust off the glass on a sensor, but I don't remember where the sensor is.
one note on this website says it may be the ohp detecting sensor (pc3a) found in front above the waste toner sensor pc6.
I opened the printer, and took out the cartridge. Do not know what to do or where to look next.
Problem two: before the fatal error message, I already could not print today because when I try to print from yahoo or from word 2007, I get a message saying I must name the file. no matter what I name the file, nothing prints, and I think I get a message saying "file not found"
any and all info about either problem much appreciated! thanks.
    Champion:
  • 214 Answers
Open side cover and there is a plastic, if you raise that plastic piece the ohp sensor should be located under this plastic
second problem, try uninstalling the printer and re install it, should solve this.
Posted on Nov 12, 2008
Fatal error code: 16H
The Belt Positioning Sensor does not detect the Transfer
Belt position detection hole a second time even after
the lapse of a predetermined period of time after it has
detected one while the Transfer Belt is rotated.
Oct 04, 2010 | Konica Minolta magicolor 2430 DL Laser...
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
Jul 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2430 DL Fatal Error Code: 12H
I advice you power off the magicolor 2430 DL and power on after few minutes, while the magicolor 2430 DL is loading or booting, pull out the plug from the AC outlet and wait for minutes before plugging it back and power on, if the problem still per, press the stop button for about 5 seconds and release, see what happens, if it fix the problem.
Let me no what happens.
Take care.
Jul 10, 2010 | Konica Minolta magicolor 2430 DL Laser...
What is a Fatal error 12h with a Konica 2430?
Originally posted by danafr :
"This error (12H) pertains to the Laser Unit of the printer which is damaged and needs to be replaced. The Laser Unit is the heart of the printer, it's what transmits the image to be printed. You need to contact a service center and will run you about $200. I had this same problem with my printer and had to call Technical Support and they gave me the bad news."
Hope this helps. =)
Oct 22, 2009 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430DLshowing Fatal o8h
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely.
Apr 18, 2009 | Konica Minolta magicolor 2430 DL Laser...
Fatal Error 12H on Konica Minolta Magicolor 2430DL
Oct 26, 2008 | Konica Minolta magicolor 2430 DL Laser...
Minolta Magicolor 2430 DL
Fatal error code 2AH: Faulty memory data.
1 - Unplug the power cord and plug it in, then turn OFF and ON the Power Switch.
2 - Check Parameter Chip (PJ26) on PWB-A for proper connection and correct as necessary.
3 - Change PWB-A. (8314139-0101-15)
4 - Change Parameter Chip.
hope it helps
regards
Sep 14, 2008 | Konica Minolta magicolor 2430 DL Laser...
Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
Aug 05, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Fatal Error 21H
FATAL ERROR CODE 21H / SERVICE CALL 21 TRANS DET SENS: Malfunction of the OHP detecting sensor
check the OHP detecting sensor (PC3A) (it's at the front above the waste toner sensor pc6)
May 22, 2008 | Konica Minolta magicolor 2300DL Laser...
Errors
Rack rotation failure, I'm not 100% that this is that error, but does the rack, where the toner are move ? if not, move it with manually a little bit then restart printer.
Nov 14, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
494 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
