Question about Aiwa NSX-MTD9 Shelf System
Snowblower whells appear to locked up
  • 45 Answers
If this is a friction drive system, see:
http://support.mtdproducts.com/cgi-bin/mtd.cfg/php/enduser/std_adp.php?p_faqid=337&p_created=1038409306&p_sid=YfaokfGj&p_accessibility=0&p_redirect=&p_lva=79&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzksNzkmcF9wcm9kcz0xMCZwX2NhdHM9MCZwX3B2PTEuMTAmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13aGVlbHMgbG9ja2Vk&p_li=&p_topview=1
If that does not help, you can download a manual for it here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
Posted on Aug 25, 2009
My 1998 ford 4x4 wont engage in 4 whell drive the lights blink but no ingage
Does your vehicle have external locking hubs? If so, make sure they are turned to lock the wheels to the hubs.
Mar 13, 2015 | Ford Cars & Trucks
New snowblower out of the box, the auger handle appears to be locked down, will not come up
they may have put something under it , free it up , or the cable is stuck in the insulation work it loose
Feb 12, 2014 | Garden
Snowblower always in gear and wont throw snow and cant move when engine is off
Service kit available for that mess of gears in the motor box(needle bearings inside the gear seize up), there is also a shear or sacrificial adapter mounted to the impeller input shaft Parts and Diagrams for MTD 31AS63EF729 2011 check around part # 7 and 15 top right hand corner. hope this helps. if this didnt help check out this web site
Feb 05, 2014 | Garden
Wheels seized
Is your drive belt too tight.that drives the wheels? When it's too tight the wheels appear to lock.
Jan 23, 2014 | Ariens Deluxe 28 Model 921022 St28le 2...
I have a 1999 Tecumsah Lawnboy 824E 8.0hp, model 28232, snowblower. Last snow the forward and reverse stopped working. The snowblower runs but the wheels locked up. I was able to get the forward and...
Here is a link that may help,ihttp://www.partstree.com/parts/?lc=lawn_boy&mn=28232. Adjust and lube the cables for drive engagement, and the other cables and Hiem joints. This usually will rectify the problem.
Apr 16, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
We have a yardworks snowblower and when not using the wheels always lock up. how do you unlock them without turning on snowblower.
Had the same issue and found out that the wheels lock when the motor isn't running and the accelerator handle is engaged. I still had both handles tied down from transporting home and it rolled fine after they were untied. Hope that helps
Oct 21, 2012 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Will not go into 4-whell drive. Floor shift seems to work OK but 4-whell light does not come on and it does not lock the hubs
You most likely have a defective part in the front differential. Typically, the transfer case is O.K Repair is not to costly.
Dec 11, 2009 | 1995 Chevrolet Suburban
KEY WON'T TURN STEERING WHEEL IS LOCKED 2008 CHEVY COLBALT
you going to have to play with the steering whell lock by rock steering wheel back and forth continiously while playing with the key at the same time jiggle the wheel and the keys.
Nov 14, 2009 | 2008 Chevrolet Cobalt
Hyundai accent 1996 steering lock removal
try tunring the key and the whell at the same time it should release the lock.
Aug 05, 2008 | 1996 Hyundai Accent
Aiwa NSX-MTD9 Shelf System Logo
117 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
