SOURCE: Pioneer Elite PRO 710HD 64" rear projection tv
You could get the old one and have them match it up. If not try www.pioneerservice.com
SOURCE: Philips 55PP9401 55 in. Rear Projection
First, repair convergence problem = replace both convergence
IC's ....STK392-110 sub to upgrade STK394-160E....I use
Hitachi part # CZ 01341.......next, look for discolored resistor
near IC's.....replace with exact value......last = activate
Auto-Intellisense.....................T.
SOURCE: LG Rear Projection Television Model RT-56NZ23RB - Fault
For my LG TV - LG RT-56NZ23RB, I replaced two STK 392-120 chips and it has fixed convergence problem now.
SOURCE: Sony KP-57WS520 57 in. Rear Projection TV standby light blinks
Please mention how many times standby light blinks on your KP-57WS520
There would be bit long pause between blinks so count the blinks and let me know to help you.
SOURCE: Hitachi 43VWX10B Rear Projection Television - color adjustment problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
