Question about Whirlpool RBS275PD Electric Single Oven
Whirlpool oven my oven makes a rattling noise when I turn it on and it sounds like a bad fanbelt.... but I dont think there is a fan in the oven. not sure if this is th exact model
  • jrdbolt Nov 17, 2008
    When oven turns on, sounds like a bad fan and same noice for a little while when the oven turns off. Any ideas on repair?
  • Whirlpool Master
  • 3,463 Answers
There is a fan in the oven, it is behind a panel at the rear.It will be a loose fan or worn bearings, or fan catching grill
Posted on Dec 15, 2008
I have a whirlpool electric range and oven door wont close all the way how can i fix this
Posted on Dec 23, 2008
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
Why is the oven fan making a rattling noise
I do not no the specific model you have but chances are that the noise you are hearing is the bearings(or brass bushings) are going out in your fan motor. Which in turn allows the shaft of the motor to not remain true and rattles. In laymen's terms, you just need a new fan motor. I hope this helps. "Be Easy!"
Feb 25, 2015 | Ovens
Bottom Oven Fan on Whirlpool AKP951 not working properly
Sounds like the fan is locking up and not turning all the time. If it is a howling sound the fan will have to be replaced.
Nov 29, 2011 | Whirlpool Ovens
In cabinet oven cooling fan does not work
it is the cooling fan if you have already replaced the thermal fuse on the back then replace the fan also shop around that price for the fan sounds high
Apr 05, 2010 | Whirlpool RBS305PDS Electric Single Oven
The oven makes a loud rattling sound when it reaches a certain heat (tends to be about 200 degrees) and then rattles intermittently until turned off. If you slam the door it does sometimes shut for a...
From what you describe is happening, I would say that it is the fan that is causing the noise, not neccesserily the oven fan, because there is an external cooling fan as well, and these are the only moving parts that could cause a noise.
Hope this helps.
Feb 02, 2010 | Candy FP855 Electric Single Oven
OVEN MAKES A LOUD NOISE WHEN IT IS TURNED ON. IT SOUNDS LIKE THE FAN IS HAVING TROUBLE TURNING OR SOMETHING.
This indigates worn or tight fan motor bearings, if it is a built in oven , then it could have an external cooling fan in addition to the oven fan, so you will have to determine which one it is.
Usually it means having to replace the offending fan motor, as lubricating only provides a short term solution.
Hope this helps.
Jan 09, 2010 | Whirlpool Ovens
Convection oven making rattling sound.
It is most likeky that the fan bearing is worn and thus causing the rattling sound. You will probably need to replace the fan. Check first that there is no obstacle in the way of the fan rotating.
Replacement of the fan will require the back of the oven to be removed giving access to the fan unit, which will need to have the wires disconnected and the fan assembly unbolted. Fitting is the reverse.
Always remember to switch off the power before working on electrical equipment.
Jan 07, 2010 | GE Ovens
Noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RBS275PD Electric Single Oven Logo
913 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
John Tripp
John Tripp
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
